QUICC Engine
QUICC Engine
1,231 次查看
guxg
I can not access the memroy of the QUICC Engine Internal Registers and QUICC Engine MURAM.
All the value I read from these memory space is 0,I write value to the  memory space and then read back,the value is still 0.
Why is this, who can answer me?
1,143 次查看
alexander_yakov
1. Please verify QE block clock settings.
2. Please verify that you are writing to correct memory offset
Alexander
