P1022: Ethernet Issue while booting from Parallel NOR Flash
1,588件の閲覧回数
senthil_k
In Our Custom P1022 based board we are facing a ethernet issue, "ethernet is not consistent in NOR Flash Boot Mode". But in the same board with SDCard boot mode ethernet is consistent.
(We are using the u-boot image build from SDK 1.9)
Please let me know is there any relation to ethernet and Flash boot mode.
2 返答(返信)
1,502件の閲覧回数
ufedor
Please provide:
1) the NOR booting U-Boot log
2) the processor connection schematics as searchable PDF (consider to create a Technical case: How I could create a Service Request? | NXP Community )
3) values of Global Utilities registers.
1,502件の閲覧回数
senthil_k
Hi Ufedor,
Thanks for your response. It was a hardware issue in our custom board, after fixing the same Ethernet is consistent in both SD-Card and flash boot mode.
