Looking for signal processing library or examples using the SPE instructions.
已解决
跳至解决方案
1,903 次查看
caryo_brien
I am looking for information about using the SPE (Signal Processing Extensions) instructions in
a P1022 processor.  The compiler (gcc) in Qoriq Yocto 1.6 seems capable of generating the
instructions, and they do work, but beyond the SPEPIM reference manual I haven't been able
to find much other support.  Are there libraries available?  We are mostly interested in audio
processing, i.e. seeing if we can handle some of the tasks currently done by dedicated DSP
chips.
Has anyone had much luck doing this?
Thanks in Advance
Cary O'Brien
标签 (1)
1 解答
1,549 次查看
yipingwang
Hello Cary O'Brien,
I find some information from our internal data base, hope the following would be helpful.
PowerQUICC III Software Library replacing some libc functions by utilizing the SPE
http://cache.freescale.com/files/netcomm/software/libraries/libcfsl_e500.zip
AN3733 : Improving DSP Performance Using Efficient SPE Coding
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN3733.pdf
MPC55xx SPE DSP Library 1
http://cache.freescale.com/files/microcontrollers/software/app_software/code_examples/MPC55xx_SPE_DS...
MPC55xx SPE DSP Library 2 ()
Yiping
在原帖中查看解决方案
1 回复
1,550 次查看
yipingwang
Hello Cary O'Brien,
Yiping
