ECM (e500 coherency module)
2,837 次查看
guillaumedehaye
Hi all,
I begin on the QorIQ P2020, and i must use the e500 coherency module, but I don't understand how to use it.
Can you help me, please?
Guims
标记 (1)
5 回复数
2,621 次查看
guillaumedehaye
Sorry for my late answer,
For Scott Wood :
That's the problem, I have no indication for use this function. What is the simple way of use it?
It's posible to use the window for this test?
Are there other registre to use (other ECM register)?
For Alexander YAKOVIEV :
I read this part and I wanted to know if we could use it after boot when we have in the main software?
Guims
PS: sorry for my English
2,621 次查看
scottwood
If you don't know what you need it for, what makes you think you need to do anything with it?  Normally it does its job without software interference.  The registers are mainly for error reporting.
2,621 次查看
guillaumedehaye
OK,
I try to use it with SRIO
Thank you
2,621 次查看
alexander_yakov
ECM coherency module is described in P2020 Reference Manual, Chapter 7 "e500 Coherency Module"
QorIQ P2020/10 Single- and Dual-Core Communic|Freescale
For initialization/application information please see Section 7.4
2,621 次查看
scottwood
What specifically are you trying to accomplish?
