which sample part can replace TDF8546JV/N2ZU
2,086件の閲覧回数
Guofred
i found the TDF8546JV/N2ZU is EOL, would you like kindly help to recommend the sample part number for replacing, thanks a lot.
Best regards.
Guofred
2,080件の閲覧回数
JozefKozon
Hi Guofred,
there must be a mistake. In our product page the TDF8546JV is showing as Active.
However a drop-in replacement is TDF8546AJV, which is a redesign of the TDF8546JV.
With Best Regards,
Jozef
2,081件の閲覧回数
JozefKozon
Hi Guofred,
With Best Regards,
Jozef
2,066件の閲覧回数
Guofred
Hi @JozefKozon ,
Thanks for your kindly help.
1) yes, thanks for your good idea, the NXP website shows the TDF8546JV/N2ZU is active.
   i would like to check the details with market again.
2)TDF8546AJV/N1ZU--->N1ZU
   TDF8546JV/N2ZU---->N2ZU
what is difference between N1ZU and N2ZU. would you like to share your comments, thanks.
Best regards.
Guofred
