wct1012
wct1012
842 次查看
chriscrippen
I am wondering if there is any way to reduce the number of required components seen in the  WCT-15W1COILTX eval kit. I have not found any information relating if a particular module is actually required or optional. IE: current, Q-factor, temp and others.
Would it be at all safe to assume that a function or pin on the WCT1012 is optional if it CAN be turned into a GPIO?
I don't feel very safe about this assumption.
Thank you for any help in advance!
0 回复数
