transistor parameters
3,218 次查看
wactener
greetings
Waclaw
4 回复数
3,092 次查看
Veronika_techsupport
Hello @wactener
you should receive the answer also to your email. To the case portal please login at this link: https://www.nxp.com/support/support:SUPPORTHOME (Support - submit a ticket).
Basicaly from the picture provided you have some old Motorola device which the most probably never became as NXP device. Please check from the current NXP product websites:
https://www.nxp.com/products/radio-frequency/rf-discrete-components-low-power/rf-wideband-transistor...
If you will need further technical support, please let us know your parameters and our production team will gladly assist you with recommendation.
Thank you. Kind regards
3,094 次查看
Hello @wactener
you should receive the answer to your email. To the case portal please login here with this link https://www.nxp.com/support/support:SUPPORTHOME Support - submit a ticket.
Please check.
3,186 次查看
Hello @wactener
please check the answer in the related case.
Thank you
3,141 次查看
wactener
Hallo @Veronika_techsupport
I can't find a related case
please help me
Thank you
