testEcAttestationChain&testRsaAttestationChain Failed
3,751 次查看
wenbo_he
Dear NXP's expert,
    I am running though the Android GTS test packages and  getting a number of failures.
testEcAttestationChain&testRsaAttestationChain Failed.
I have got the googlekey file attest_keyboxes.xxx-nxp.output.
My question is how to make it work on the device?
Could you please give me some guidance documents.
Thanks in advanced !
B.R.
7 回复数
3,557 次查看
nxf45548
To assist you properly, can you please let us know the part number that you are using.
3,557 次查看
wenbo_he
Hardware : Freescale i.MX6 Quad/DualLite (Device Tree)
3,557 次查看
joanxie
I found this link, maybe customer can check google key first,
https://www.itread01.com/content/1541408407.html
3,557 次查看
wenbo_he
Dear Joan,
I've got the attestation "keybox" from Google.
I want to know how to flash the attestation keys to device i.MX6.
Thanks.
3,557 次查看
joanxie
it seems that you need refer to the security user guide  which is under NDA, so you need to get NDA first
3,557 次查看
wenbo_he
Dear Joan,
I found some program attestation key commands from Android_User's_Guide.pdf,
which is downloaded from https://community.nxp.com/servlet/JiveServlet/download/1267028-1-465427/Android_User%27s_Guide.pdf
content as following,
8.11 Key attestation
Fastboot commands are provided to provision the attestation keys and certificates. Make sure the secure storage is properlyinitialized for Trusty OS:
• Set RSA private key:
fastboot stage <path-to-rsa-private-key>
fastboot oem set-rsa-atte-key
Unfortunately, the above command is not supported on imx6.
Could you tell me if the method in the security user guide is the same as the above?
If not, how can I apply for the NDA?
Thanks.
3,557 次查看
joanxie
for NDA, you need to contact local representative or create a case in salesforce:
Distributor Network | NXP
https://community.nxp.com/docs/DOC-329745
