stop PWM
stop PWM
1,192 次查看
Nadia
I'm using the microcontroller LPC54616J, and two pins to take out PWM signals and control a motor, I have a problem when I want to change the pin, I don't know how to stop the PWM and activate the other one, I thought that with SCTIMER_StopTimer it would work, but it doesn't.
If anyone knows how to do this I thank them for their help.
Thank you very much.
Greetings
1,147 次查看
Omar_Anguiano
Hello
You can use as reference the examples in the AN11538. The SCTimer/PWM start_stop example can be useful for your application.
Let me know if this is helpful, if you have more questions do not hesitate to ask me.
Omar
