regarding bin file generation
967件の閲覧回数
venkataramana1
To generate a bin file i followed the below procedure but file is generated but it is showing old date and all the files are showing same date what is the solution to generate the files upto date
/home/icomm/distro/sources/poky/meta-skeleton/recipes-skeleton/hello-single/files in the above path i have created dot c file and in below path i have created .bb file it is generating bin files in the following path /distro/build_ls1043ardb/tmp/work/ls1043ardb-fsl-linux/fsl-image-mfgtool/1.0-r0/rootfs/bin but it is showing outdated file
914件の閲覧回数
June_Lu
Please Cleans various images refer to
Layerscape Linux Distribution POC User Guide, Rev. L6.1.1-1.0.0
Page 21, Table 8. bitbake commands, and try again.
