mc145010
mc145010
661件の閲覧回数
fpgiovanini
According Figure 8. Typical Battery-Powered Application in the MC145010 DATASHEET.
There is no reflection inside the chamber but sunddenly the LED start blinking several times nonetheless the output I/O was not triggered.
which conditions make the LED this behaviour?
where this information is available?
633件の閲覧回数
JozefKozon
Dear fpgiovanini,
the LED can blink under several conditions not related to smoke detection:
  1. Low-Supply Voltage Condition:
    • The chip periodically checks the supply voltage using a pulsed load current from the LED pin.
    • If the voltage drops below a threshold (set by external resistors), the LED flashes alongside a beep or chirp to indicate low battery.
  2. Degraded Chamber Sensitivity:
    • The IC performs periodic checks for chamber sensitivity degradation.
    • A beep occurring halfway between LED flashes indicates this condition.
  3. Push Button Test Mode:
    • If the test button is pressed, the IC enters high-gain mode and may cause the LED to blink as part of the test sequence.
  4. Power-On Reset or Internal Monitoring:
    • Upon power-up or during standby, the IC may perform internal checks that momentarily activate the LED.
With Best Regards,
Jozef
%3CLINGO-SUB%20id%3D%22lingo-sub-2172283%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Emc145010%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2172283%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMC145010%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AE%E5%9B%B3%208.%20%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E9%A7%86%E5%8B%95%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%81%E3%83%A3%E3%83%B3%E3%83%90%E3%83%BC%E5%86%85%E3%81%AB%E3%81%AF%E5%8F%8D%E5%B0%84%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E5%87%BA%E5%8A%9B%20I%2FO%20%E3%81%8C%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%E7%AA%81%E7%84%B6%20LED%20%E3%81%8C%E6%95%B0%E5%9B%9E%E7%82%B9%E6%BB%85%E3%81%97%E5%A7%8B%E3%82%81%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ELED%20%E3%81%8C%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E6%9D%A1%E4%BB%B6%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%AF%E3%81%A9%E3%81%93%E3%81%A7%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2172655%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20mc145010%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2172655%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3Efpgiovanini%3C%2FSPAN%3E%E6%A7%98%3C%2FP%3E%0A%3CP%3ELED%20%E3%81%AF%E7%85%99%E6%A4%9C%E7%9F%A5%E3%81%A8%E3%81%AF%E9%96%A2%E4%BF%82%E3%81%AE%E3%81%AA%E3%81%84%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E6%9D%A1%E4%BB%B6%E4%B8%8B%E3%81%A7%E7%82%B9%E6%BB%85%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%0A%3CP%3E%E4%BD%8E%E9%9B%BB%E6%BA%90%E9%9B%BB%E5%9C%A7%E7%8A%B6%E6%85%8B%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E3%83%81%E3%83%83%E3%83%97%E3%81%AF%E3%80%81LED%20%E3%83%94%E3%83%B3%E3%81%8B%E3%82%89%E3%81%AE%E3%83%91%E3%83%AB%E3%82%B9%E8%B2%A0%E8%8D%B7%E9%9B%BB%E6%B5%81%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E5%AE%9A%E6%9C%9F%E7%9A%84%E3%81%AB%E9%9B%BB%E6%BA%90%E9%9B%BB%E5%9C%A7%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E9%9B%BB%E5%9C%A7%E3%81%8C%E3%81%97%E3%81%8D%E3%81%84%E5%80%A4%EF%BC%88%E5%A4%96%E9%83%A8%E6%8A%B5%E6%8A%97%E5%99%A8%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E8%A8%AD%E5%AE%9A%EF%BC%89%E3%82%92%E4%B8%8B%E5%9B%9E%E3%82%8B%E3%81%A8%E3%80%81LED%20%E3%81%8C%E7%82%B9%E6%BB%85%E3%81%97%E3%80%81%E3%83%93%E3%83%BC%E3%83%97%E9%9F%B3%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%81%E3%83%A3%E3%83%BC%E3%83%97%E9%9F%B3%E3%81%8C%E9%B3%B4%E3%82%8A%E3%80%81%E3%83%90%E3%83%83%E3%83%86%E3%83%AA%E3%83%BC%E6%AE%8B%E9%87%8F%E3%81%8C%E5%B0%91%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%E3%83%81%E3%83%A3%E3%83%B3%E3%83%90%E3%83%BC%E6%84%9F%E5%BA%A6%E3%81%AE%E4%BD%8E%E4%B8%8B%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EIC%20%E3%81%AF%E3%83%81%E3%83%A3%E3%83%B3%E3%83%90%E3%83%BC%E3%81%AE%E6%84%9F%E5%BA%A6%E4%BD%8E%E4%B8%8B%E3%81%8C%E3%81%AA%E3%81%84%E3%81%8B%E5%AE%9A%E6%9C%9F%E7%9A%84%E3%81%AB%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3ELED%20%E3%81%AE%E7%82%B9%E6%BB%85%E3%81%AE%E9%80%94%E4%B8%AD%E3%81%A7%E3%83%93%E3%83%BC%E3%83%97%E9%9F%B3%E3%81%8C%E9%B3%B4%E3%82%8B%E3%81%A8%E3%80%81%E3%81%93%E3%81%AE%E7%8A%B6%E6%85%8B%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%E3%83%97%E3%83%83%E3%82%B7%E3%83%A5%E3%83%9C%E3%82%BF%E3%83%B3%E3%83%86%E3%82%B9%E3%83%88%E3%83%A2%E3%83%BC%E3%83%89%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E3%83%86%E3%82%B9%E3%83%88%20%E3%83%9C%E3%82%BF%E3%83%B3%E3%81%8C%E6%8A%BC%E3%81%95%E3%82%8C%E3%82%8B%E3%81%A8%E3%80%81IC%20%E3%81%AF%E9%AB%98%E3%82%B2%E3%82%A4%E3%83%B3%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8A%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%20%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%A8%E3%81%97%E3%81%A6%20LED%20%E3%81%8C%E7%82%B9%E6%BB%85%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%E3%83%91%E3%83%AF%E3%83%BC%E3%82%AA%E3%83%B3%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%BE%E3%81%9F%E3%81%AF%E5%86%85%E9%83%A8%E3%83%A2%E3%83%8B%E3%82%BF%E3%83%AA%E3%83%B3%E3%82%B0%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E9%9B%BB%E6%BA%90%E6%8A%95%E5%85%A5%E6%99%82%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E4%B8%AD%E3%81%AB%E3%80%81IC%20%E3%81%AF%E5%86%85%E9%83%A8%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81%E4%B8%80%E6%99%82%E7%9A%84%E3%81%AB%20LED%20%E3%82%92%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JozefKozon_0-1758271185227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JozefKozon_0-1758271185227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F357719i2CCDB9675141C0AB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JozefKozon_0-1758271185227.png%22%20alt%3D%22JozefKozon_0-1758271185227.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JozefKozon_1-1758271241591.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JozefKozon_1-1758271241591.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F357720iA91C627E0187B4A8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JozefKozon_1-1758271241591.png%22%20alt%3D%22JozefKozon_1-1758271241591.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JozefKozon_2-1758271299247.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JozefKozon_2-1758271299247.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F357725iED2F7912108295F9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JozefKozon_2-1758271299247.png%22%20alt%3D%22JozefKozon_2-1758271299247.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JozefKozon_3-1758271351797.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JozefKozon_3-1758271351797.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F357726iBDA2F7300F0DDE1B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JozefKozon_3-1758271351797.png%22%20alt%3D%22JozefKozon_3-1758271351797.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%95%AC%E5%85%B7%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%83%A8%E3%82%BC%E3%83%95%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
