mc145010
mc145010
fpgiovanini
According Figure 8. Typical Battery-Powered Application in the MC145010 DATASHEET.
There is no reflection inside the chamber but sunddenly the LED start blinking several times nonetheless the output I/O was not triggered.
which conditions make the LED this behaviour?
where this information is available?
JozefKozon
Dear fpgiovanini,
the LED can blink under several conditions not related to smoke detection:
  1. Low-Supply Voltage Condition:
    • The chip periodically checks the supply voltage using a pulsed load current from the LED pin.
    • If the voltage drops below a threshold (set by external resistors), the LED flashes alongside a beep or chirp to indicate low battery.
  2. Degraded Chamber Sensitivity:
    • The IC performs periodic checks for chamber sensitivity degradation.
    • A beep occurring halfway between LED flashes indicates this condition.
  3. Push Button Test Mode:
    • If the test button is pressed, the IC enters high-gain mode and may cause the LED to blink as part of the test sequence.
  4. Power-On Reset or Internal Monitoring:
    • Upon power-up or during standby, the IC may perform internal checks that momentarily activate the LED.
With Best Regards,
Jozef
%3CLINGO-SUB%20id%3D%22lingo-sub-2172283%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Emc145010%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2172283%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAccording%26nbsp%3BFigure%208.%20Typical%20Battery-Powered%20Application%20in%20the%20MC145010%20DATASHEET.%3C%2FP%3E%3CP%3EThere%20is%20no%20reflection%20inside%20the%20chamber%20but%20sunddenly%20the%20LED%20start%20blinking%20several%20times%20nonetheless%20the%20output%20I%2FO%20was%20not%20triggered.%3C%2FP%3E%3CP%3Ewhich%20conditions%20make%20the%20LED%20this%20behaviour%3F%26nbsp%3B%3C%2FP%3E%3CP%3Ewhere%20this%20information%20is%20available%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2172655%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20mc145010%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2172655%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%26nbsp%3B%3CSPAN%3Efpgiovanini%2C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3Ethe%20LED%20can%20blink%20under%20several%20conditions%20not%20related%20to%20smoke%20detection%3A%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%0A%3CP%3ELow-Supply%20Voltage%20Condition%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EThe%20chip%20periodically%20checks%20the%20supply%20voltage%20using%20a%20pulsed%20load%20current%20from%20the%20LED%20pin.%3C%2FLI%3E%0A%3CLI%3EIf%20the%20voltage%20drops%20below%20a%20threshold%20(set%20by%20external%20resistors)%2C%20the%20LED%20flashes%20alongside%20a%20beep%20or%20chirp%20to%20indicate%20low%20battery.%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3EDegraded%20Chamber%20Sensitivity%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EThe%20IC%20performs%20periodic%20checks%20for%20chamber%20sensitivity%20degradation.%3C%2FLI%3E%0A%3CLI%3EA%20beep%20occurring%20halfway%20between%20LED%20flashes%20indicates%20this%20condition.%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3EPush%20Button%20Test%20Mode%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EIf%20the%20test%20button%20is%20pressed%2C%20the%20IC%20enters%20high-gain%20mode%20and%20may%20cause%20the%20LED%20to%20blink%20as%20part%20of%20the%20test%20sequence.%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3EPower-On%20Reset%20or%20Internal%20Monitoring%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EUpon%20power-up%20or%20during%20standby%2C%20the%20IC%20may%20perform%20internal%20checks%20that%20momentarily%20activate%20the%20LED.%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JozefKozon_0-1758271185227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JozefKozon_0-1758271185227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F357719i2CCDB9675141C0AB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JozefKozon_0-1758271185227.png%22%20alt%3D%22JozefKozon_0-1758271185227.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JozefKozon_1-1758271241591.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JozefKozon_1-1758271241591.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F357720iA91C627E0187B4A8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JozefKozon_1-1758271241591.png%22%20alt%3D%22JozefKozon_1-1758271241591.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JozefKozon_2-1758271299247.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JozefKozon_2-1758271299247.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F357725iED2F7912108295F9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JozefKozon_2-1758271299247.png%22%20alt%3D%22JozefKozon_2-1758271299247.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JozefKozon_3-1758271351797.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JozefKozon_3-1758271351797.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F357726iBDA2F7300F0DDE1B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JozefKozon_3-1758271351797.png%22%20alt%3D%22JozefKozon_3-1758271351797.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EWith%20Best%20Regards%2C%3C%2FP%3E%0A%3CP%3EJozef%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
