lv_group_focus_obj(); Set focus, control does not respond
3,202件の閲覧回数
qqt_996
lv_group_t* group = lv_group_create();
lv_group_add_obj(group, ui->Parameters_list_1_item0);
lv_group_add_obj(group, ui->Parameters_list_1_item1);
lv_indev_set_group(keypadIndevice, group);
lv_group_focus_obj(ui->Parameters_list_1_item1);
lv_group_focus_obj(); Set the focus, the control has no response, which is successful in some interfaces
6 返答(返信)
3,109件の閲覧回数
Veronika_techsupport
Hello @qqt_996
Unfortunately "v8.3.10" this is not valid NXP part number therefore I am not able to redirect your request to responsible team. Please provide us with this information so that we can provide you with accurate support.
Kind regards
3,137件の閲覧回数
Hello @qqt_996
could you please share the NXP part/device you are using to be able to redirect your query properly?
Thank you
Kind regards
3,122件の閲覧回数
qqt_996
lvgl version v8.3.10,Setting the default focus was successful, but the control style did not change
3,181件の閲覧回数
Hello @qqt_996
Could you please also share which NXP part number you are using?
Thank you in advance.
3,151件の閲覧回数
qqt_996
3,166件の閲覧回数
qqt_996
v8.3.10
