imxrt1170 evkb doesn't connect
2,289件の閲覧回数
nicomarconi
Hi, i was working perfectlly with the board, and start working and debugging display RK055HDMIPI4M0, and all of the sudden, i couldn´t debug any more, i tried the board in another computer and the same error have ocurred, please y need help, because nothing work right now...
2,264件の閲覧回数
EdwinHz
Hi @nicomarconi,
Please follow the steps described on the following knowledge base article in order to recover debug access to your i.MX RT device: RT board recovery for debugger connect issues - NXP Community
BR,
Edwin.
5 返答(返信)
2,265件の閲覧回数
EdwinHz
Hi @nicomarconi,
BR,
Edwin.
2,255件の閲覧回数
nicomarconi
Good morning, i just want to say THANK YOU. It is amazing to have an a really quick answer with a technical problem. Because this type of problem doesn´t let you to go ahead.
I have followed  the steps , and now i can run the hello world again.
Is there any way to avoid the repetition of this problem in the future?
Thank you so much for your help. I fell very supportive with you
2,254件の閲覧回数
nicomarconi
Hi, sorry for my quick answer before, i am really greatful for youe help.
What have happen after my last email, eas that y put back the switches to the normal configuration, and i got the same problem that before..
With the switch number 4 in ON position every work ok, but with the 4 switch in OFF and the 3rd switch in ON, as in factory configuration, i got the same problem than before.
What should i do?
thanks a lot
2,253件の閲覧回数
nicomarconi
So sorry for my last massage , i have folloed the memory erase again, and now it is working perfectly.
I repeat my thanks you a lot. It is extremely important to have support from you, even more at the beginning..
Have a wonderful day
2,214件の閲覧回数
EdwinHz
Hi @nicomarconi,
Happy to help! As you mentioned yourself, if you ever loose debug access to your i.MX RT device, simply follow the instructions of the article I shared, and you should be able to recover it without any issues.
If you have any further inquiries, do let me know!
BR,
Edwin.
