implementing usb for imx8 nano processor
Jayesh2408
trying to implement usb for imx8 nano, the eval board layout shows floating wire for Id pin. will it work for host mode? because id need to be =0 for host mode.
Manuel_Salas
Hello @Jayesh2408
Hope you are doing very well.
Yes, a floating ID pin will work perfectly fine for host-only mode, provided you force the controller behavior via software.
You can just change the dr_mode property in device tree from "otg" to "host":
&usbotg1 {
	dr_mode = "host";
	hnp-disable;
	srp-disable;
	adp-disable;
	usb-role-switch;
	disable-over-current;
	samsung,picophy-pre-emp-curr-control = <3>;
	samsung,picophy-dc-vol-level-adjust = <7>;
	status = "okay";
	port {
		usb1_drd_sw: endpoint {
			remote-endpoint = <&typec1_dr_sw>;
Salas.
%3CLINGO-SUB%20id%3D%22lingo-sub-2415780%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eimplementing%20usb%20for%20imx8%20nano%20processor%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2415780%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Etrying%20to%20implement%20usb%20for%20imx8%20nano%2C%20the%20eval%20board%20layout%20shows%20floating%20wire%20for%20Id%20pin.%20will%20it%20work%20for%20host%20mode%3F%20because%20id%20need%20to%20be%20%3D0%20for%20host%20mode.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2415822%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20implementing%20usb%20for%20imx8%20nano%20processor%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2415822%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F266650%22%20target%3D%22_blank%22%3E%40Jayesh2408%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EHope%20you%20are%20doing%20very%20well.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EYes%2C%20a%20floating%20ID%20pin%20will%20work%20perfectly%20fine%20for%20host-only%20mode%2C%20provided%20you%20force%20the%20controller%20behavior%20via%20software.%3C%2FP%3E%0A%3CP%3EYou%20can%20just%20change%20the%20%3CSTRONG%3Edr_mode%3C%2FSTRONG%3E%20property%20in%20device%20tree%20from%20%22%3CSTRONG%3Eotg%3C%2FSTRONG%3E%22%20to%20%22%3CSTRONG%3Ehost%3C%2FSTRONG%3E%22%3A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E%26amp%3Busbotg1%20%7B%0A%09dr_mode%20%3D%20%22host%22%3B%0A%09hnp-disable%3B%0A%09srp-disable%3B%0A%09adp-disable%3B%0A%09usb-role-switch%3B%0A%09disable-over-current%3B%0A%09samsung%2Cpicophy-pre-emp-curr-control%20%3D%20%26lt%3B3%26gt%3B%3B%0A%09samsung%2Cpicophy-dc-vol-level-adjust%20%3D%20%26lt%3B7%26gt%3B%3B%0A%09status%20%3D%20%22okay%22%3B%0A%0A%09port%20%7B%0A%09%09usb1_drd_sw%3A%20endpoint%20%7B%0A%09%09%09remote-endpoint%20%3D%20%26lt%3B%26amp%3Btypec1_dr_sw%26gt%3B%3B%0A%09%09%7D%3B%0A%09%7D%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3ESalas.%3C%2FP%3E%3C%2FLINGO-BODY%3E
