[i.mx8mn] Applying kernel changes I modifed
ソリューションへジャンプ
2,023件の閲覧回数
bryan_hong
Senior Contributor I
dear nxp
When I modifed setup.c on `tmp/work-shared/imx8mn-lpddr4-evk/kernel-sourcearch/arm64/kernel/setup.c` as below.
pr_info("BBBooting Linux on physical CPU 0x%010lx [0x%08x]\n",
 (unsigned long)mpidr, read_cpuid_id());
then, I have executed below command.
$ bitbake -c compile -f linux-imx && bitbake -c deploy linux-imx
$ bitbake core-image-base
then I have flash the image as below.
tmp\deploy\images\imx8mn-lpddr4-evk> uuu -b emmc_all imx-boot-imx8mn-lpddr4-evk-sd.bin-flash_evk imx-image-core-imx8mn-lpddr4-evk.wic.zst
BUT, It still present not `BBBooting ` but `Booting`.
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.1.36+g04b05c5527e9 (oe-user@oe-host) (aarch64-poky-linux-gcc (GCC) 12.3.0, GNU ld (GNU Binutils) 2.40.0.20230620) #1 SMP PREEMPT Mon Sep 4 21:11:15 UTC 2023
How to apply changes in setup.c to the kernel.
Bryan
タグ(1)
1,466件の閲覧回数
bryan_hong
dear Zhiming
I have checked the boot using kernel I modifed with below command on uboot mode.
setenv ipaddr 192.168.1.162
setenv serverip 192.168.1.143
tftpboot ${loadaddr} Image
tftpboot ${fdt_addr_r} imx8mn-evk-imx8mn-lpddr4-evk.dtb
booti ${loadaddr} - ${fdt_addr_r}
Thanks for your support.
タグ(1)
5 返答(返信)
1,903件の閲覧回数
bryan_hong
dear  Zhiming_Liu
I'm looking for the way to flash kernel image to the i.mx8mn EVK without toggling dip switch download mode(SW1101).
Alike `fastboot flash boot boot.img` on android.
Bryan
1,876件の閲覧回数
Zhiming_Liu
Hi @bryan_hong
You can run fastboot usb 0 in uboot, try to use fastboot to flash.
platform-tools> .\fastboot.exe getvar version-bootloader
version-bootloader: U-Boot 2025.04-g44898b9f3cfe
Finished. Total time: 0.005s
u-boot/doc/android/fastboot.rst at master · u-boot/u-boot
Zhiming
1,467件の閲覧回数
bryan_hong
dear Zhiming
タグ(1)
1,568件の閲覧回数
bryan_hong
dear Zhiming
As you know, ADB, fastboot did not work because I use linux OS.
Bryan
1,994件の閲覧回数
Zhiming_Liu
Hi @bryan_hong
Please use 'devtool modify linux-imx' to unpack linux-imx into build-xxx/workspace/source/, then recompile it.
Zhiming
%3CLINGO-SUB%20id%3D%22lingo-sub-2268255%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5Bi.mx8mn%5D%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2268255%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8BNXP%3C%2FP%3E%3CP%3E%60tmp%2Fwork-shared%2Fimx8mn-lpddr4-evk%2Fkernel-sourcearch%2Farm64%2Fkernel%2Fsetup.c%60%20%E3%81%AE%20setup.c%20%E3%82%92%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Epr_info(%22%20%E7%89%A9%E7%90%86CPU%200x%25010lx%20%5B0x%2508x%5D%20%E3%81%A7%20Linux%20%E3%82%92%3CSTRONG%3EBBBooting%20%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%5Cn%22%2C%3CBR%20%2F%3E%20(%E7%AC%A6%E5%8F%B7%E3%81%AA%E3%81%97long)mpidr%E3%80%81read_cpuid_id())%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%24%20bitbake%20-c%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%20-f%20linux-imx%20%26amp%3B%26amp%3B%20bitbake%20-c%20%E3%83%87%E3%83%97%E3%83%AD%E3%82%A4%20linux-imx%3C%2FP%3E%3CP%3E%24%20bitbake%20%E3%82%B3%E3%82%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%83%99%E3%83%BC%E3%82%B9%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Etmp%5Cdeploy%5Cimages%5Cimx8mn-lpddr4-evk%26gt%3B%20uuu%20-b%20emmc_all%20imx-boot-imx8mn-lpddr4-evk-sd.bin-flash_evkimx-image-core-imx8mn-lpddr4-evk.wic.zst%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%60%20%3CSTRONG%3EBBBooting%3C%2FSTRONG%3E%20%60%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%20%60%20%3CSTRONG%3EBooting%3C%2FSTRONG%3E%20%60%20%E3%81%8C%E3%81%BE%E3%81%A0%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E4%B8%AD%E2%80%A6%3C%2FP%3E%3CP%3E%5B%200.000000%5D%20%E7%89%A9%E7%90%86CPU%200x0000000000%20%5B0x410fd034%5D%20%E3%81%A7Linux%3CSTRONG%3E%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3CBR%20%2F%3E%5B%200.000000%5D%20Linux%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B36.1.36%2Bg04b05c5527e9(oe-user%40oe-host)%20(aarch64-poky-linux-gcc%20(GCC)%2012.3.0%E3%80%81GNU%20ld%20(GNU%20Binutils)%202.40.0.20230620)%20%231%20SMP%20PREEMPT%20%E6%9C%88%E6%9B%9C%E6%97%A5%209%20%E6%9C%88%204%20%E6%97%A5%2021%3A11%3A15%20UTC%202023%3C%2FP%3E%3CP%3Esetup.c%20%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%3CBR%20%2F%3E%E3%83%96%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2268375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5Bi.mx8mn%5D%20Applying%20kernel%20changes%20I%20modifed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2268375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F107445%22%20target%3D%22_blank%22%3E%40bryan_hong%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20%E3%80%8C%20%3CSTRONG%3Edevtool%20modify%20linux-imx%3C%2FSTRONG%3E%20%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20linux-imx%20%E3%82%92%20build-xxx%2Fworkspace%2Fsource%2F%20%E3%81%AB%E8%A7%A3%E5%87%8D%E3%81%97%E3%80%81%E5%86%8D%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2269563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5Bi.mx8mn%5D%20Applying%20kernel%20changes%20I%20modifed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2269563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_self%22%3E%3CSPAN%20class%3D%22%22%3EZhiming_Liu%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%82%A3%E3%83%83%E3%83%97%E3%83%BB%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%83%A2%E3%83%BC%E3%83%89%20(SW1101)%20%E3%82%92%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%9A%E3%81%AB%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%20i.mx8mn%20EVK%20%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EAndroid%20%E3%81%AE%20%60fastboot%20flash%20boot%20boot.img%60%20%E3%81%AB%E4%BC%BC%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%3CBR%20%2F%3E%E3%83%96%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2269720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5Bi.mx8mn%5D%20Applying%20kernel%20changes%20I%20modifed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2269720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F107445%22%20target%3D%22_blank%22%3E%40bryan_hong%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20uboot%20%E3%81%A7%3CSTRONG%3Efastboot%20usb%200%3C%2FSTRONG%3E%E3%82%92CAN%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82fastboot%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eplatform-tools%26gt%3B%20.%5Cfastboot.exe%20getvar%20version-bootloader%0Aversion-bootloader%3A%20U-Boot%202025.04-g44898b9f3cfe%0AFinished.%20Total%20time%3A%200.005s%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fu-boot%2Fu-boot%2Fblob%2Fmaster%2Fdoc%2Fandroid%2Ffastboot.rst%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Eu-boot%2Fdoc%2Fandroid%2Ffastboot.rst%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%20%C2%B7%20u-boot%2Fu-boot%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E5%BF%97%E6%98%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2289963%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5Bi.mx8mn%5D%20Applying%20kernel%20changes%20I%20modifed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2289963%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%3CSPAN%3E%E5%BF%97%E6%98%8E%E3%81%95%E3%82%93%3C%2FSPAN%3E%E3%81%B8%3C%2FP%3E%3CP%3E%E3%81%94%E5%AD%98%E7%9F%A5%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%80%81Linux%20OS%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81ADB%E3%80%81fastboot%20%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%3CBR%20%2F%3E%E3%83%96%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2291537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5Bi.mx8mn%5D%20Applying%20kernel%20changes%20I%20modifed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2291537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A6%AA%E6%84%9B%E3%81%AA%E3%82%8B%3CSPAN%3E%E5%BF%97%E6%98%8E%E3%81%95%E3%82%93%3C%2FSPAN%3E%E3%81%B8%3C%2FP%3E%3CP%3Euboot%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%96%E3%83%BC%E3%83%88%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3Esetenv%20ipaddr%20192.168.1.162%3C%2FP%3E%3CP%3Esetenv%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AEIP%E3%82%92%20192.168.1.143%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Etftpboot%20%24%7Bloadaddr%7D%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FP%3E%3CP%3Etftpboot%20%24%7Bfdt_addr_r%7D%20imx8mn-evk-imx8mn-lpddr4-evk.dtb%3C%2FP%3E%3CP%3E%E3%83%96%E3%83%BC%E3%83%86%E3%82%A3%24%7Bloadaddr%7D%20-%20%24%7Bfdt_addr_r%7D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
