[i.mx8mn] Applying kernel changes I modifed
1,927 次查看
bryan_hong
Senior Contributor I
dear nxp
When I modifed setup.c on `tmp/work-shared/imx8mn-lpddr4-evk/kernel-sourcearch/arm64/kernel/setup.c` as below.
pr_info("BBBooting Linux on physical CPU 0x%010lx [0x%08x]\n",
 (unsigned long)mpidr, read_cpuid_id());
then, I have executed below command.
$ bitbake -c compile -f linux-imx && bitbake -c deploy linux-imx
$ bitbake core-image-base
then I have flash the image as below.
tmp\deploy\images\imx8mn-lpddr4-evk> uuu -b emmc_all imx-boot-imx8mn-lpddr4-evk-sd.bin-flash_evk imx-image-core-imx8mn-lpddr4-evk.wic.zst
BUT, It still present not `BBBooting ` but `Booting`.
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.1.36+g04b05c5527e9 (oe-user@oe-host) (aarch64-poky-linux-gcc (GCC) 12.3.0, GNU ld (GNU Binutils) 2.40.0.20230620) #1 SMP PREEMPT Mon Sep 4 21:11:15 UTC 2023
How to apply changes in setup.c to the kernel.
Bryan
标记 (1)
1,370 次查看
bryan_hong
dear Zhiming
I have checked the boot using kernel I modifed with below command on uboot mode.
setenv ipaddr 192.168.1.162
setenv serverip 192.168.1.143
tftpboot ${loadaddr} Image
tftpboot ${fdt_addr_r} imx8mn-evk-imx8mn-lpddr4-evk.dtb
booti ${loadaddr} - ${fdt_addr_r}
Thanks for your support.
标记 (1)
5 回复数
1,807 次查看
bryan_hong
dear  Zhiming_Liu
I'm looking for the way to flash kernel image to the i.mx8mn EVK without toggling dip switch download mode(SW1101).
Alike `fastboot flash boot boot.img` on android.
Bryan
1,780 次查看
Zhiming_Liu
Hi @bryan_hong
You can run fastboot usb 0 in uboot, try to use fastboot to flash.
platform-tools> .\fastboot.exe getvar version-bootloader
version-bootloader: U-Boot 2025.04-g44898b9f3cfe
Finished. Total time: 0.005s
u-boot/doc/android/fastboot.rst at master · u-boot/u-boot
Zhiming
1,371 次查看
bryan_hong
dear Zhiming
标记 (1)
1,472 次查看
bryan_hong
dear Zhiming
As you know, ADB, fastboot did not work because I use linux OS.
Bryan
1,898 次查看
Zhiming_Liu
Hi @bryan_hong
Please use 'devtool modify linux-imx' to unpack linux-imx into build-xxx/workspace/source/, then recompile it.
Zhiming
%3CLINGO-SUB%20id%3D%22lingo-sub-2268255%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5Bi.mx8mn%5D%20%E5%BA%94%E7%94%A8%E6%88%91%E4%BF%AE%E6%94%B9%E8%BF%87%E7%9A%84%E5%86%85%E6%A0%B8%E5%8F%98%E6%9B%B4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2268255%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%3C%2FP%3E%3CP%3E%E6%88%91%E5%AF%B9%20%60tmp%2Fwork-shared%2Fimx8mn-lpddr4-evk%2Fkernel-sourcearch%2Farm64%2Fkernel%2Fsetup.c%60%20%E4%B8%8A%E7%9A%84%20setup.c%20%E8%BF%9B%E8%A1%8C%E4%BA%86%E5%A6%82%E4%B8%8B%E4%BF%AE%E6%94%B9%E3%80%82%3C%2FP%3E%3CP%3Epr_info(%22%3CSTRONG%3E%20BBBooting%3C%2FSTRONG%3E%20Linux%20on%20physical%20CPU%200x%25010lx%20%5B0x%2508x%5D%5Cn%22%2C%3CBR%20%2F%3E%20(unsigned%20long)mpidr%2C%20read_cpuid_id())%EF%BC%9B%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%EF%BC%8C%E6%88%91%E6%89%A7%E8%A1%8C%E4%BA%86%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E3%80%82%3C%2FP%3E%3CP%3E%24%20bitbake%20-c%20compile%20-f%20linux-imx%26amp%3B%26amp%3B%20bitbake%20-c%20deploy%20linux-imx%3C%2FP%3E%3CP%3E%24%20bitbake%20core-image-base%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%84%B6%E5%90%8E%EF%BC%8C%E6%88%91%E9%97%AA%E7%83%81%E4%BA%86%E5%A6%82%E4%B8%8B%E5%9B%BE%E5%83%8F%E3%80%82%3C%2FP%3E%3CP%3Etmp%5Cdeploy%5Cimages%5Cimx8mn-lpddr4-evk%26gt%3B%20uuu%20-b%20emmc_all%20imx-%E5%90%AF%E5%8A%A8-imx8mn-lpddr4-evk-sd.bin-flash_evkimx-image-core-imx8mn-lpddr4-evk.wic.zst%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%AE%83%E4%BB%8D%E7%84%B6%E4%B8%8D%E6%98%AF%20%3CSTRONG%3EbbBooting%20%E8%80%8C%E6%98%AF%20bbB%3C%2FSTRONG%3E%20%3CSTRONG%3Eoo%3C%2FSTRONG%3E%20ting%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%9C%A8%E5%90%AF%E5%8A%A8%E5%86%85%E6%A0%B8...%3C%2FP%3E%3CP%3E%5B0.000000%5D%20%E5%9C%A8%E7%89%A9%E7%90%86%20CPU%20%E4%B8%8A%3CSTRONG%3E%E5%90%AF%E5%8A%A8%3C%2FSTRONG%3E%20Linux%200x0000000000%20%5B0x410fd034%5D%20%5B0.000000%5D%20Linux%20%E7%89%88%E6%9C%AC%206.1.36%2Bg04b05c5527e9%20%3CBR%20%2F%3E(oe-user%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F50695%22%20target%3D%22_blank%22%3E%40OE%3C%2FA%3E-host)%20(aarch64-poky-linux-gcc%20(GCC)%2012.3.0%EF%BC%8CGNU%20ld%20(GNU%20Binutils)%202.40.0.20230620)%20%231%20SMP%20PREEMPT%20Mon%20Sep%204%2021%3A11%3A15%20UTC%202023%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E5%B0%86%20setup.c%20%E4%B8%AD%E7%9A%84%E6%9B%B4%E6%94%B9%E5%BA%94%E7%94%A8%E4%BA%8E%E5%86%85%E6%A0%B8%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%3CBR%20%2F%3EBryan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2268375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5Bi.mx8mn%5D%20Applying%20kernel%20changes%20I%20modifed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2268375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F107445%22%20target%3D%22_blank%22%3E%40bryan_hong%3C%2FA%3E%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%20%E8%AF%B7%E4%BD%BF%E7%94%A8%20%E2%80%9C%3CSTRONG%3Edevtool%20%E4%BF%AE%E6%94%B9%20linux-imx%3C%2FSTRONG%3E%E2%80%9D%20%E5%B0%86%20linux-imx%20%E8%A7%A3%E5%8E%8B%E7%BC%A9%E5%88%B0%20%E7%89%88%E6%9C%AC-xxx%2Fworkspace%2Fsource%2F%20%E4%B8%AD%EF%BC%8C%E7%84%B6%E5%90%8E%E9%87%8D%E6%96%B0%E7%BC%96%E8%AF%91%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E6%95%AC%EF%BC%8C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2269563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5Bi.mx8mn%5D%20Applying%20kernel%20changes%20I%20modifed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2269563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%3CSPAN%3E%20%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F151788%22%20target%3D%22_self%22%3E%3CSPAN%20class%3D%22%22%3E%E5%88%98%E5%BF%97%E6%98%8E%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E5%AF%BB%E6%89%BE%E4%B8%8D%E7%94%A8%E6%8B%A8%E5%8A%A8%E4%B8%8B%E8%BD%BD%E6%A8%A1%E5%BC%8F%E6%8B%A8%E7%A0%81%E5%BC%80%E5%85%B3%EF%BC%88SW1101%EF%BC%89%E5%B0%B1%E8%83%BD%E5%B0%86%E5%86%85%E6%A0%B8%E6%98%A0%E5%83%8F%E9%97%AA%E5%AD%98%E5%88%B0%20i.mx8mn%20EVK%20%E7%9A%84%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%3CP%3E%E5%B0%B1%E5%83%8F%E5%AE%89%E5%8D%93%E4%B8%8A%E7%9A%84%20fastboot%20flash%20%E5%90%AF%E5%8A%A8%20boot.img%20%E4%B8%80%E6%A0%B7%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%3CBR%20%2F%3EBryan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2269720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5Bi.mx8mn%5D%20Applying%20kernel%20changes%20I%20modifed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2269720%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F107445%22%20target%3D%22_blank%22%3E%40bryan_hong%3C%2FA%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%9C%A8%20uboot%20%E4%B8%AD%E8%BF%90%E8%A1%8C%3CSTRONG%3Efastboot%20usb%200%3C%2FSTRONG%3E%EF%BC%8C%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20fastboot%20%E9%97%AA%E5%AD%98%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eplatform-tools%26gt%3B%20.%5Cfastboot.exe%20getvar%20version-bootloader%0Aversion-bootloader%3A%20U-Boot%202025.04-g44898b9f3cfe%0AFinished.%20Total%20time%3A%200.005s%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fu-boot%2Fu-boot%2Fblob%2Fmaster%2Fdoc%2Fandroid%2Ffastboot.rst%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Eu-boot%2Fdoc%2Fandroid%2Ffastboot.rst%20at%20master%20%C2%B7%20u-boot%2Fu-boot%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E6%95%AC%EF%BC%8C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2289963%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5Bi.mx8mn%5D%20Applying%20kernel%20changes%20I%20modifed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2289963%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E5%BF%97%E6%98%8E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%A0%E6%89%80%E7%9F%A5%EF%BC%8CADB%20%E5%92%8C%20fastboot%20%E9%83%BD%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20linux%20%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%3CBR%20%2F%3EBryan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2291537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5Bi.mx8mn%5D%20Applying%20kernel%20changes%20I%20modifed%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2291537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E5%BF%97%E6%98%8E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E4%BD%BF%E7%94%A8%E6%88%91%E5%9C%A8uboot%E6%A8%A1%E5%BC%8F%E4%B8%8B%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E4%BF%AE%E6%94%B9%E7%9A%84%E5%86%85%E6%A0%B8%E6%A3%80%E6%9F%A5%E4%BA%86%E5%90%AF%E5%8A%A8%E6%83%85%E5%86%B5%E3%80%82%3C%2FP%3E%3CP%3Esetenv%20ipaddr%20192.168.1.162%3C%2FP%3E%3CP%3Esetenv%20serverip%20192.168.1.143%3C%2FP%3E%3CP%3Etftpboot%24%7Bloadaddr%7D%20%E5%9B%BE%E5%83%8F%3C%2FP%3E%3CP%3Etftpboot%24%7Bfdt_addr_r%7D%20imx8mn-evk-imx8mn-lpddr4-evk.dtb%3C%2FP%3E%3CP%3Ebooti%24%7Bloadaddr%7D%20-%24%7Bfdt_addr_r%7D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E
