eIQ Toolkit 1.16 does not work in Ubuntu 22.04
823 次查看
deneriz
I've downloaded eIQ Toolkit 1.16.0.106 Ubuntu Installer and installed it with:
chmod +x eiq-toolkit-v1.16.0.106-1_amd64_b250703.deb.bin
sudo ./eiq-toolkit-v1.16.0.106-1_amd64_b250703.deb.bin
If I launch the eIQ Toolkit portal I  get the following:
source /opt/nxp/eIQ_Toolkit_v1.16.0/bin/eiqenv.sh && /opt/nxp/eIQ_Toolkit_v1.16.0/eiq-portal
eIQ Portal version 2.16.0
/opt/nxp/eIQ_Toolkit_v1.16.0/resources/app.asar
Launch -> /opt/nxp/eIQ_Toolkit_v1.16.0
is-elevated: false
09:36:34.254 › Launching Application
Display size is 1920x1080
[2025-08-01T07:36:34.582Z] ExtensionHostController running as pid 23867
[2025-08-01T07:36:35.018Z] InstalledExtensionsReady barrier opened
[2025-08-01T07:36:35.049Z] Socket.io logging server connected to socket COKliSleb6yc_PxXAAAB
(buffered) [2025-08-01T07:36:34.906Z] ExtensionHost running as pid 23976
(buffered) [2025-08-01T07:36:35.036Z] Connected to sqlite:///home/deneriz/.config/eiqportal-nodejs/state.sqlite
09:36:35.133 › [CONVERTER] 2025-08-01 09:36:35.129579: E external/local_xla/xla/stream_executor/cuda/cuda_fft.cc:477] Unable to register cuFFT factory: Attempting to register factory for plugin cuFFT when one has already been registered
09:36:35.144 › [CONVERTER] WARNING: All log messages before absl::InitializeLog() is called are written to STDERR
E0000 00:00:1754033795.144002   24023 cuda_dnn.cc:8310] Unable to register cuDNN factory: Attempting to register factory for plugin cuDNN when one has already been registered
09:36:35.148 › [CONVERTER] E0000 00:00:1754033795.148069   24023 cuda_blas.cc:1418] Unable to register cuBLAS factory: Attempting to register factory for plugin cuBLAS when one has already been registered
09:36:35.162 › [CONVERTER] 2025-08-01 09:36:35.161826: I tensorflow/core/platform/cpu_feature_guard.cc:210] This TensorFlow binary is optimized to use available CPU instructions in performance-critical operations.
To enable the following instructions: AVX2 AVX_VNNI FMA, in other operations, rebuild TensorFlow with the appropriate compiler flags.
09:36:35.238 › [TRAINER] 2025-08-01 09:36:35.237425: E external/local_xla/xla/stream_executor/cuda/cuda_fft.cc:477] Unable to register cuFFT factory: Attempting to register factory for plugin cuFFT when one has already been registered
09:36:35.253 › [TRAINER] WARNING: All log messages before absl::InitializeLog() is called are written to STDERR
E0000 00:00:1754033795.252816   24037 cuda_dnn.cc:8310] Unable to register cuDNN factory: Attempting to register factory for plugin cuDNN when one has already been registered
09:36:35.257 › [TRAINER] E0000 00:00:1754033795.257420   24037 cuda_blas.cc:1418] Unable to register cuBLAS factory: Attempting to register factory for plugin cuBLAS when one has already been registered
09:36:35.273 › [TRAINER] 2025-08-01 09:36:35.273235: I tensorflow/core/platform/cpu_feature_guard.cc:210] This TensorFlow binary is optimized to use available CPU instructions in performance-critical operations.
09:36:35.319 › [IMPORTER] 2025-08-01 09:36:35.318661: E external/local_xla/xla/stream_executor/cuda/cuda_fft.cc:477] Unable to register cuFFT factory: Attempting to register factory for plugin cuFFT when one has already been registered
09:36:35.335 › [IMPORTER] WARNING: All log messages before absl::InitializeLog() is called are written to STDERR
E0000 00:00:1754033795.335405   24038 cuda_dnn.cc:8310] Unable to register cuDNN factory: Attempting to register factory for plugin cuDNN when one has already been registered
09:36:35.340 › [IMPORTER] E0000 00:00:1754033795.340386   24038 cuda_blas.cc:1418] Unable to register cuBLAS factory: Attempting to register factory for plugin cuBLAS when one has already been registered
09:36:35.355 › [IMPORTER] 2025-08-01 09:36:35.354815: I tensorflow/core/platform/cpu_feature_guard.cc:210] This TensorFlow binary is optimized to use available CPU instructions in performance-critical operations.
[2025-08-01T07:36:35.435Z] Socket.io logging server connected to socket qQ74H5beOrLxNSpSAAAD
libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
  0%|          | 0/1 [00:00<?, ?it/s]
[23867:0801/093636.004460:FATAL:gpu_data_manager_impl_private.cc(415)] GPU process isn't usable. Goodbye.
However, my GPU is CUDA usable:
nvidia-smi
Fri Aug  1 09:37:00 2025
| NVIDIA-SMI 565.57.01              Driver Version: 565.57.01      CUDA Version: 12.7     |
| GPU  Name                 Persistence-M | Bus-Id          Disp.A | Volatile Uncorr. ECC |
| Fan  Temp   Perf          Pwr:Usage/Cap |           Memory-Usage | GPU-Util  Compute M. |
|                                         |                        |               MIG M. |
|   0  NVIDIA GeForce RTX 4060 ...    On  |   00000000:01:00.0  On |                  N/A |
| N/A   43C    P4             11W /   55W |    1054MiB /   8188MiB |     56%      Default |
|                                         |                        |                  N/A |
I'm on Ubuntu 22.04:
lsb_release -a
No LSB modules are available.
Distributor ID:	Ubuntu
Description:	Ubuntu 22.04.5 LTS
Release:	22.04
Codename:	jammy
Where can I find the official installation instructions for eIQ Toolkit 1.16? Is there a way to launch the eIQ Toolkit without GPU? Why the eIQ Toolkit Portal not booting?
771 次查看
deneriz
破坏者
772 次查看
deneriz
破坏者
%3CLINGO-SUB%20id%3D%22lingo-sub-2144996%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EeIQ%20%E5%B7%A5%E5%85%B7%E5%8C%85%201.16%20%E6%97%A0%E6%B3%95%E5%9C%A8%20Ubuntu%2022.04%20%E4%B8%AD%E8%BF%90%E8%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144996%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E4%B8%8B%E8%BD%BD%E4%BA%86%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DEIQ-TOOLKIT-LINUX-V1.16.0.106%26amp%3BappType%3Dfile1%26amp%3BDOWNLOAD_ID%3Dnull%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%3EeIQ%20%E5%B7%A5%E5%85%B7%E5%8C%85%201.16.0.106%20Ubuntu%20%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%3C%2FSPAN%3E%3C%2FA%3E%E5%B9%B6%E7%94%A8%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Echmod%20%2Bx%20eiq-toolkit-v1.16.0.106-1_amd64_b250703.deb.bin%0Asudo%20.%2Feiq-toolkit-v1.16.0.106-1_amd64_b250703.deb.bin%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E7%94%A8%E4%B8%8A%E5%B8%82%20eIQ%20Toolkit%20%E9%97%A8%E6%88%B7%EF%BC%8C%E6%88%91%E4%BC%9A%E5%BE%97%E5%88%B0%E4%BB%A5%E4%B8%8B%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Esource%20%2Fopt%2Fnxp%2FeIQ_Toolkit_v1.16.0%2Fbin%2Feiqenv.sh%20%26amp%3B%26amp%3B%20%2Fopt%2Fnxp%2FeIQ_Toolkit_v1.16.0%2Feiq-portal%0AeIQ%20Portal%20version%202.16.0%20%0A------------------------------------------------%0A%2Fopt%2Fnxp%2FeIQ_Toolkit_v1.16.0%2Fresources%2Fapp.asar%0A------------------------------------------------%0ALaunch%20-%26gt%3B%20%2Fopt%2Fnxp%2FeIQ_Toolkit_v1.16.0%0Ais-elevated%3A%20false%0A09%3A36%3A34.254%20%E2%80%BA%20Launching%20Application%0ADisplay%20size%20is%201920x1080%0A%5B2025-08-01T07%3A36%3A34.582Z%5D%20ExtensionHostController%20running%20as%20pid%2023867%0A%5B2025-08-01T07%3A36%3A35.018Z%5D%20InstalledExtensionsReady%20barrier%20opened%0A%5B2025-08-01T07%3A36%3A35.049Z%5D%20Socket.io%20logging%20server%20connected%20to%20socket%20COKliSleb6yc_PxXAAAB%0A(buffered)%20%5B2025-08-01T07%3A36%3A34.906Z%5D%20ExtensionHost%20running%20as%20pid%2023976%0A(buffered)%20%5B2025-08-01T07%3A36%3A35.036Z%5D%20Connected%20to%20sqlite%3A%2F%2F%2Fhome%2Fdeneriz%2F.config%2Feiqportal-nodejs%2Fstate.sqlite%0A09%3A36%3A35.133%20%E2%80%BA%20%5BCONVERTER%5D%202025-08-01%2009%3A36%3A35.129579%3A%20E%20external%2Flocal_xla%2Fxla%2Fstream_executor%2Fcuda%2Fcuda_fft.cc%3A477%5D%20Unable%20to%20register%20cuFFT%20factory%3A%20Attempting%20to%20register%20factory%20for%20plugin%20cuFFT%20when%20one%20has%20already%20been%20registered%0A%0A09%3A36%3A35.144%20%E2%80%BA%20%5BCONVERTER%5D%20WARNING%3A%20All%20log%20messages%20before%20absl%3A%3AInitializeLog()%20is%20called%20are%20written%20to%20STDERR%0AE0000%2000%3A00%3A1754033795.144002%20%20%2024023%20cuda_dnn.cc%3A8310%5D%20Unable%20to%20register%20cuDNN%20factory%3A%20Attempting%20to%20register%20factory%20for%20plugin%20cuDNN%20when%20one%20has%20already%20been%20registered%0A%0A09%3A36%3A35.148%20%E2%80%BA%20%5BCONVERTER%5D%20E0000%2000%3A00%3A1754033795.148069%20%20%2024023%20cuda_blas.cc%3A1418%5D%20Unable%20to%20register%20cuBLAS%20factory%3A%20Attempting%20to%20register%20factory%20for%20plugin%20cuBLAS%20when%20one%20has%20already%20been%20registered%0A%0A09%3A36%3A35.162%20%E2%80%BA%20%5BCONVERTER%5D%202025-08-01%2009%3A36%3A35.161826%3A%20I%20tensorflow%2Fcore%2Fplatform%2Fcpu_feature_guard.cc%3A210%5D%20This%20TensorFlow%20binary%20is%20optimized%20to%20use%20available%20CPU%20instructions%20in%20performance-critical%20operations.%0ATo%20enable%20the%20following%20instructions%3A%20AVX2%20AVX_VNNI%20FMA%2C%20in%20other%20operations%2C%20rebuild%20TensorFlow%20with%20the%20appropriate%20compiler%20flags.%0A%0A09%3A36%3A35.238%20%E2%80%BA%20%5BTRAINER%5D%202025-08-01%2009%3A36%3A35.237425%3A%20E%20external%2Flocal_xla%2Fxla%2Fstream_executor%2Fcuda%2Fcuda_fft.cc%3A477%5D%20Unable%20to%20register%20cuFFT%20factory%3A%20Attempting%20to%20register%20factory%20for%20plugin%20cuFFT%20when%20one%20has%20already%20been%20registered%0A%0A09%3A36%3A35.253%20%E2%80%BA%20%5BTRAINER%5D%20WARNING%3A%20All%20log%20messages%20before%20absl%3A%3AInitializeLog()%20is%20called%20are%20written%20to%20STDERR%0AE0000%2000%3A00%3A1754033795.252816%20%20%2024037%20cuda_dnn.cc%3A8310%5D%20Unable%20to%20register%20cuDNN%20factory%3A%20Attempting%20to%20register%20factory%20for%20plugin%20cuDNN%20when%20one%20has%20already%20been%20registered%0A%0A09%3A36%3A35.257%20%E2%80%BA%20%5BTRAINER%5D%20E0000%2000%3A00%3A1754033795.257420%20%20%2024037%20cuda_blas.cc%3A1418%5D%20Unable%20to%20register%20cuBLAS%20factory%3A%20Attempting%20to%20register%20factory%20for%20plugin%20cuBLAS%20when%20one%20has%20already%20been%20registered%0A%0A09%3A36%3A35.273%20%E2%80%BA%20%5BTRAINER%5D%202025-08-01%2009%3A36%3A35.273235%3A%20I%20tensorflow%2Fcore%2Fplatform%2Fcpu_feature_guard.cc%3A210%5D%20This%20TensorFlow%20binary%20is%20optimized%20to%20use%20available%20CPU%20instructions%20in%20performance-critical%20operations.%0ATo%20enable%20the%20following%20instructions%3A%20AVX2%20AVX_VNNI%20FMA%2C%20in%20other%20operations%2C%20rebuild%20TensorFlow%20with%20the%20appropriate%20compiler%20flags.%0A%0A09%3A36%3A35.319%20%E2%80%BA%20%5BIMPORTER%5D%202025-08-01%2009%3A36%3A35.318661%3A%20E%20external%2Flocal_xla%2Fxla%2Fstream_executor%2Fcuda%2Fcuda_fft.cc%3A477%5D%20Unable%20to%20register%20cuFFT%20factory%3A%20Attempting%20to%20register%20factory%20for%20plugin%20cuFFT%20when%20one%20has%20already%20been%20registered%0A%0A09%3A36%3A35.335%20%E2%80%BA%20%5BIMPORTER%5D%20WARNING%3A%20All%20log%20messages%20before%20absl%3A%3AInitializeLog()%20is%20called%20are%20written%20to%20STDERR%0AE0000%2000%3A00%3A1754033795.335405%20%20%2024038%20cuda_dnn.cc%3A8310%5D%20Unable%20to%20register%20cuDNN%20factory%3A%20Attempting%20to%20register%20factory%20for%20plugin%20cuDNN%20when%20one%20has%20already%20been%20registered%0A%0A09%3A36%3A35.340%20%E2%80%BA%20%5BIMPORTER%5D%20E0000%2000%3A00%3A1754033795.340386%20%20%2024038%20cuda_blas.cc%3A1418%5D%20Unable%20to%20register%20cuBLAS%20factory%3A%20Attempting%20to%20register%20factory%20for%20plugin%20cuBLAS%20when%20one%20has%20already%20been%20registered%0A%0A09%3A36%3A35.355%20%E2%80%BA%20%5BIMPORTER%5D%202025-08-01%2009%3A36%3A35.354815%3A%20I%20tensorflow%2Fcore%2Fplatform%2Fcpu_feature_guard.cc%3A210%5D%20This%20TensorFlow%20binary%20is%20optimized%20to%20use%20available%20CPU%20instructions%20in%20performance-critical%20operations.%0ATo%20enable%20the%20following%20instructions%3A%20AVX2%20AVX_VNNI%20FMA%2C%20in%20other%20operations%2C%20rebuild%20TensorFlow%20with%20the%20appropriate%20compiler%20flags.%0A%0A%5B2025-08-01T07%3A36%3A35.435Z%5D%20Socket.io%20logging%20server%20connected%20to%20socket%20qQ74H5beOrLxNSpSAAAD%0Alibva%20error%3A%20vaGetDriverNameByIndex()%20failed%20with%20unknown%20libva%20error%2C%20driver_name%20%3D%20(null)%0Alibva%20error%3A%20vaGetDriverNameByIndex()%20failed%20with%20unknown%20libva%20error%2C%20driver_name%20%3D%20(null)%0Alibva%20error%3A%20vaGetDriverNameByIndex()%20failed%20with%20unknown%20libva%20error%2C%20driver_name%20%3D%20(null)%0Alibva%20error%3A%20vaGetDriverNameByIndex()%20failed%20with%20unknown%20libva%20error%2C%20driver_name%20%3D%20(null)%0A%20%200%25%7C%20%20%20%20%20%20%20%20%20%20%7C%200%2F1%20%5B00%3A00%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E4%B8%8D%E8%BF%87%EF%BC%8C%E6%88%91%E7%9A%84%20GPU%20%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20CUDA%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Envidia-smi%0AFri%20Aug%20%201%2009%3A37%3A00%202025%20%20%20%20%20%20%20%0A%2B-----------------------------------------------------------------------------------------%2B%0A%7C%20NVIDIA-SMI%20565.57.01%20%20%20%20%20%20%20%20%20%20%20%20%20%20Driver%20Version%3A%20565.57.01%20%20%20%20%20%20CUDA%20Version%3A%2012.7%20%20%20%20%20%7C%0A%7C-----------------------------------------%2B------------------------%2B----------------------%2B%0A%7C%20GPU%20%20Name%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20Persistence-M%20%7C%20Bus-Id%20%20%20%20%20%20%20%20%20%20Disp.A%20%7C%20Volatile%20Uncorr.%20ECC%20%7C%0A%7C%20Fan%20%20Temp%20%20%20Perf%20%20%20%20%20%20%20%20%20%20Pwr%3AUsage%2FCap%20%7C%20%20%20%20%20%20%20%20%20%20%20Memory-Usage%20%7C%20GPU-Util%20%20Compute%20M.%20%7C%0A%7C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20MIG%20M.%20%7C%0A%7C%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%2B%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%2B%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%7C%0A%7C%20%20%200%20%20NVIDIA%20GeForce%20RTX%204060%20...%20%20%20%20On%20%20%7C%20%20%2000000000%3A01%3A00.0%20%20On%20%7C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20N%2FA%20%7C%0A%7C%20N%2FA%20%20%2043C%20%20%20%20P4%20%20%20%20%20%20%20%20%20%20%20%20%2011W%20%2F%20%20%2055W%20%7C%20%20%20%201054MiB%20%2F%20%20%208188MiB%20%7C%20%20%20%20%2056%25%20%20%20%20%20%20Default%20%7C%0A%7C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%7C%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20N%2FA%20%7C%0A%2B-----------------------------------------%2B------------------------%2B----------------------%2B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20Ubuntu%2022.04%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Elsb_release%20-a%0ANo%20LSB%20modules%20are%20available.%0ADistributor%20ID%3A%09Ubuntu%0ADescription%3A%09Ubuntu%2022.04.5%20LTS%0ARelease%3A%0922.04%0ACodename%3A%09jammy%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%20eIQ%20%E5%B7%A5%E5%85%B7%E5%8C%85%201.16%20%E7%9A%84%E5%AE%98%E6%96%B9%E5%AE%89%E8%A3%85%E8%AF%B4%E6%98%8E%EF%BC%9F%E6%9C%89%E6%B2%A1%E6%9C%89%E5%8A%9E%E6%B3%95%E5%9C%A8%E6%B2%A1%E6%9C%89%20GPU%20%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E7%94%A8%E4%B8%8A%E5%B8%82%20eIQ%20%E5%B7%A5%E5%85%B7%E5%8C%85%EF%BC%9F%E4%B8%BA%E4%BB%80%E4%B9%88%20eIQ%20%E5%B7%A5%E5%85%B7%E5%8C%85%E9%97%A8%E6%88%B7%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2167786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20eIQ%20Toolkit%201.16%20does%20not%20work%20in%20Ubuntu%2022.04%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2167786%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22lia-spoiler-container%22%3E%3CA%20class%3D%22lia-spoiler-link%22%20href%3D%22%23%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E5%89%A7%E9%80%8F%3C%2FA%3E%3CNOSCRIPT%3E%20%EF%BC%88%E9%AB%98%E4%BA%AE%E9%83%A8%E5%88%86%E5%8F%AF%E4%BE%9B%E9%98%85%E8%AF%BB%EF%BC%89%3C%2FNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-border%22%3E%3CDIV%20class%3D%22lia-spoiler-content%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FOther-NXP-Products%2FeIQ-Toolkit-does-not-work-in-Ubuntu-22-04%2Fm-p%2F2167348%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FOther-NXP-Products%2FeIQ-Toolkit-does-not-work-in-Ubuntu-22-04%2Fm-p%2F2167348%3C%2FA%3E%E7%9A%84%E9%87%8D%E5%A4%8D%3C%2FDIV%3E%3CNOSCRIPT%3E%3CDIV%20class%3D%22lia-spoiler-noscript-container%22%3E%3CDIV%20class%3D%22lia-spoiler-noscript-content%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FOther-NXP-Products%2FeIQ-Toolkit-does-not-work-in-Ubuntu-22-04%2Fm-p%2F2167348%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FOther-NXP-Products%2FeIQ-Toolkit-does-not-work-in-Ubuntu-22-04%2Fm-p%2F2167348%3C%2FA%3E%20%E7%9A%84%E9%87%8D%E5%A4%8D%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FNOSCRIPT%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
