base-files error when build the yocto linux
Tuna38
Build the yocto error. When i build and follow to guide of nxp by yocto. How to fix the error?
WARNING: Logfile for failed setscene task is /home/vmc/Desktop/imx-yocto-bsp/build-wayland/tmp/work/armv8a-poky-linux/ptest-runner/2.4.5+git/temp/log.do_package_setscene.1680451
WARNING: Setscene task (/home/vmc/Desktop/imx-yocto-bsp/sources/poky/meta/recipes-support/ptest-runner/ptest-runner_2.4.5.bb:do_package_setscene) failed with exit code '1' - real task will be run instead
ERROR: base-files-3.0.14-r0 do_package: Error executing a python function in exec_func_python() autogenerated:
The stack trace of python calls that resulted in this exception/failure was:
File: 'exec_func_python() autogenerated', lineno: 2, function: <module>
0001:
*** 0002:perform_packagecopy(d)
0003:
File: '/home/vmc/Desktop/imx-yocto-bsp/sources/poky/meta/classes-global/package.bbclass', lineno: 363, function: perform_packagecopy
0359: rpath_replace (dvar, d)
0360:}
0361:perform_packagecopy[cleandirs] = "${PKGD}"
0362:perform_packagecopy[dirs] = "${PKGD}"
*** 0363:
0364:python populate_packages () {
0365: oe.package.populate_packages(d)
0366:}
0367:populate_packages[dirs] = "${D}"
File: '/usr/lib/python3.10/subprocess.py', lineno: 421, function: check_output
0417: else:
0418: empty = b''
0419: kwargs['input'] = empty
0420:
*** 0421: return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
0422: **kwargs).stdout
0423:
0424:
0425:class CompletedProcess(object):
File: '/usr/lib/python3.10/subprocess.py', lineno: 526, function: run
0522: # We don't call process.wait() as .__exit__ does that for us.
0523: raise
0524: retcode = process.poll()
0525: if check and retcode:
*** 0526: raise CalledProcessError(retcode, process.args,
0527: output=stdout, stderr=stderr)
0528: return CompletedProcess(process.args, retcode, stdout, stderr)
0529:
0530:
Exception: subprocess.CalledProcessError: Command 'tar --exclude=./sysroot-only -cf - -C /home/vmc/Desktop/imx-yocto-bsp/build-wayland/tmp/work/imx8mqevk-poky-linux/base-files/3.0.14/image -p -S . | tar -xf - -C /home/vmc/Desktop/imx-yocto-bsp/build-wayland/tmp/work/imx8mqevk-poky-linux/base-files/3.0.14/package' returned non-zero exit status 2.
Subprocess output:
got *at() syscall for unknown directory, fd 4
unknown base path for fd 4, path bin
couldn't allocate absolute path for 'bin'.
tar: ./usr/bin: Cannot mkdir: Bad address
unknown base path for fd 4, path lib
couldn't allocate absolute path for 'lib'.
tar: ./usr/lib: Cannot mkdir: Bad address
unknown base path for fd 4, path games
couldn't allocate absolute path for 'games'.
tar: ./usr/games: Cannot mkdir: Bad address
unknown base path for fd 4, path share
couldn't allocate absolute path for 'share'.
tar: ./usr/share: Cannot mkdir: Bad address
tar: ./usr/share/dict: Cannot mkdir: No such file or directory
tar: ./usr/share/man: Cannot mkdir: No such file or directory
tar: ./usr/share/doc: Cannot mkdir: No such file or directory
tar: ./usr/share/doc/base-files-3.0.14: Cannot mkdir: No such file or directory
tar: ./usr/share/misc: Cannot mkdir: No such file or directory
tar: ./usr/share/common-licenses: Cannot mkdir: No such file or directory
tar: ./usr/share/info: Cannot mkdir: No such file or directory
unknown base path for fd 4, path sbin
couldn't allocate absolute path for 'sbin'.
tar: ./usr/sbin: Cannot mkdir: Bad address
unknown base path for fd 4, path src
couldn't allocate absolute path for 'src'.
tar: ./usr/src: Cannot mkdir: Bad address
unknown base path for fd 4, path include
couldn't allocate absolute path for 'include'.
tar: ./usr/include: Cannot mkdir: Bad address
unknown base path for fd 4, path tmp
couldn't allocate absolute path for 'tmp'.
tar: ./var/tmp: Cannot create symlink to ‘volatile/tmp’: Bad address
unknown base path for fd 4, path local
couldn't allocate absolute path for 'local'.
tar: ./var/local: Cannot mkdir: Bad address
tar: ./var/lib: Cannot mkdir: Bad address
tar: ./var/lib/misc: Cannot mkdir: No such file or directory
unknown base path for fd 4, path volatile
couldn't allocate absolute path for 'volatile'.
tar: ./var/volatile: Cannot mkdir: Bad address
tar: ./var/volatile/tmp: Cannot mkdir: No such file or directory
tar: ./var/volatile/log: Cannot mkdir: No such file or directory
unknown base path for fd 4, path log
couldn't allocate absolute path for 'log'.
tar: ./var/log: Cannot create symlink to ‘volatile/log’: Bad address
unknown base path for fd 4, path lock
couldn't allocate absolute path for 'lock'.
tar: ./var/lock: Cannot open: Bad address
unknown base path for fd 4, path spool
couldn't allocate absolute path for 'spool'.
tar: ./var/spool: Cannot mkdir: Bad address
unknown base path for fd 4, path backups
couldn't allocate absolute path for 'backups'.
tar: ./var/backups: Cannot mkdir: Bad address
unknown base path for fd 4, path run
couldn't allocate absolute path for 'run'.
tar: ./var/run: Cannot open: Bad address
unknown base path for fd 4, path nsswitch.conf
couldn't allocate absolute path for 'nsswitch.conf'.
tar: ./etc/nsswitch.conf: Cannot open: Bad address
unknown base path for fd 4, path hosts
couldn't allocate absolute path for 'hosts'.
tar: ./etc/hosts: Cannot open: Bad address
unknown base path for fd 4, path issue.net
couldn't allocate absolute path for 'issue.net'.
tar: ./etc/issue.net: Cannot open: Bad address
unknown base path for fd 4, path profile
couldn't allocate absolute path for 'profile'.
tar: ./etc/profile: Cannot open: Bad address
unknown base path for fd 4, path default
couldn't allocate absolute path for 'default'.
tar: ./etc/default: Cannot mkdir: Bad address
couldn't allocate absolute path for 'issue'.
tar: ./etc/issue: Cannot open: Bad address
unknown base path for fd 4, path skel
couldn't allocate absolute path for 'skel'.
tar: ./etc/skel: Cannot mkdir: Bad address
tar: ./etc/skel/.profile: Cannot open: No such file or directory
tar: ./etc/skel/.bashrc: Cannot open: No such file or directory
unknown base path for fd 4, path mtab
couldn't allocate absolute path for 'mtab'.
tar: ./etc/mtab: Cannot open: Bad address
unknown base path for fd 4, path hostname
couldn't allocate absolute path for 'hostname'.
tar: ./etc/hostname: Cannot open: Bad address
unknown base path for fd 4, path fstab
couldn't allocate absolute path for 'fstab'.
tar: ./etc/fstab: Cannot open: Bad address
unknown base path for fd 4, path shells
couldn't allocate absolute path for 'shells'.
tar: ./etc/shells: Cannot open: Bad address
unknown base path for fd 4, path host.conf
couldn't allocate absolute path for 'host.conf'.
tar: ./etc/host.conf: Cannot open: Bad address
unknown base path for fd 4, path motd
couldn't allocate absolute path for 'motd'.
tar: ./etc/motd: Cannot open: Bad address
tar: Exiting with failure status due to previous errors
ERROR: Logfile of failure stored in: /home/vmc/Desktop/imx-yocto-bsp/build-wayland/tmp/work/imx8mqevk-poky-linux/base-files/3.0.14/temp/log.do_package.1734591
ERROR: Task (/home/vmc/Desktop/imx-yocto-bsp/sources/poky/meta/recipes-core/base-files/base-files_3.0.14.bb:do_package) failed with exit code '1'
yipingwang
On your ubuntu PC, run the command "sudo apt install tar=1.34+dfsg-1build3"
yipingwang
Tuna38
Thanks u. It actived
%3CLINGO-SUB%20id%3D%22lingo-sub-2398500%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ebase-files%20error%20when%20build%20the%20yocto%20linux%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2398500%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EBuild%20the%20yocto%20error.%20When%20i%20build%20and%20follow%20to%20guide%20of%20nxp%20by%20yocto.%20How%20to%20fix%20the%20error%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EWARNING%3A%20Logfile%20for%20failed%20setscene%20task%20is%20%2Fhome%2Fvmc%2FDesktop%2Fimx-yocto-bsp%2Fbuild-wayland%2Ftmp%2Fwork%2Farmv8a-poky-linux%2Fptest-runner%2F2.4.5%2Bgit%2Ftemp%2Flog.do_package_setscene.1680451%3CBR%20%2F%3EWARNING%3A%20Setscene%20task%20(%2Fhome%2Fvmc%2FDesktop%2Fimx-yocto-bsp%2Fsources%2Fpoky%2Fmeta%2Frecipes-support%2Fptest-runner%2Fptest-runner_2.4.5.bb%3Ado_package_setscene)%20failed%20with%20exit%20code%20'1'%20-%20real%20task%20will%20be%20run%20instead%3CBR%20%2F%3EERROR%3A%20base-files-3.0.14-r0%20do_package%3A%20Error%20executing%20a%20python%20function%20in%20exec_func_python()%20autogenerated%3A%3C%2FP%3E%3CP%3EThe%20stack%20trace%20of%20python%20calls%20that%20resulted%20in%20this%20exception%2Ffailure%20was%3A%3CBR%20%2F%3EFile%3A%20'exec_func_python()%20autogenerated'%2C%20lineno%3A%202%2C%20function%3A%20%3CMODULE%3E%3CBR%20%2F%3E0001%3A%3CBR%20%2F%3E***%200002%3Aperform_packagecopy(d)%3CBR%20%2F%3E0003%3A%3CBR%20%2F%3EFile%3A%20'%2Fhome%2Fvmc%2FDesktop%2Fimx-yocto-bsp%2Fsources%2Fpoky%2Fmeta%2Fclasses-global%2Fpackage.bbclass'%2C%20lineno%3A%20363%2C%20function%3A%20perform_packagecopy%3CBR%20%2F%3E0359%3A%20rpath_replace%20(dvar%2C%20d)%3CBR%20%2F%3E0360%3A%7D%3CBR%20%2F%3E0361%3Aperform_packagecopy%5Bcleandirs%5D%20%3D%20%22%24%7BPKGD%7D%22%3CBR%20%2F%3E0362%3Aperform_packagecopy%5Bdirs%5D%20%3D%20%22%24%7BPKGD%7D%22%3CBR%20%2F%3E***%200363%3A%3CBR%20%2F%3E0364%3Apython%20populate_packages%20()%20%7B%3CBR%20%2F%3E0365%3A%20oe.package.populate_packages(d)%3CBR%20%2F%3E0366%3A%7D%3CBR%20%2F%3E0367%3Apopulate_packages%5Bdirs%5D%20%3D%20%22%24%7BD%7D%22%3CBR%20%2F%3EFile%3A%20'%2Fusr%2Flib%2Fpython3.10%2Fsubprocess.py'%2C%20lineno%3A%20421%2C%20function%3A%20check_output%3CBR%20%2F%3E0417%3A%20else%3A%3CBR%20%2F%3E0418%3A%20empty%20%3D%20b''%3CBR%20%2F%3E0419%3A%20kwargs%5B'input'%5D%20%3D%20empty%3CBR%20%2F%3E0420%3A%3CBR%20%2F%3E***%200421%3A%20return%20run(*popenargs%2C%20stdout%3DPIPE%2C%20timeout%3Dtimeout%2C%20check%3DTrue%2C%3CBR%20%2F%3E0422%3A%20**kwargs).stdout%3CBR%20%2F%3E0423%3A%3CBR%20%2F%3E0424%3A%3CBR%20%2F%3E0425%3Aclass%20CompletedProcess(object)%3A%3CBR%20%2F%3EFile%3A%20'%2Fusr%2Flib%2Fpython3.10%2Fsubprocess.py'%2C%20lineno%3A%20526%2C%20function%3A%20run%3CBR%20%2F%3E0522%3A%20%23%20We%20don't%20call%20process.wait()%20as%20.__exit__%20does%20that%20for%20us.%3CBR%20%2F%3E0523%3A%20raise%3CBR%20%2F%3E0524%3A%20retcode%20%3D%20process.poll()%3CBR%20%2F%3E0525%3A%20if%20check%20and%20retcode%3A%3CBR%20%2F%3E***%200526%3A%20raise%20CalledProcessError(retcode%2C%20process.args%2C%3CBR%20%2F%3E0527%3A%20output%3Dstdout%2C%20stderr%3Dstderr)%3CBR%20%2F%3E0528%3A%20return%20CompletedProcess(process.args%2C%20retcode%2C%20stdout%2C%20stderr)%3CBR%20%2F%3E0529%3A%3CBR%20%2F%3E0530%3A%3CBR%20%2F%3EException%3A%20subprocess.CalledProcessError%3A%20Command%20'tar%20--exclude%3D.%2Fsysroot-only%20-cf%20-%20-C%20%2Fhome%2Fvmc%2FDesktop%2Fimx-yocto-bsp%2Fbuild-wayland%2Ftmp%2Fwork%2Fimx8mqevk-poky-linux%2Fbase-files%2F3.0.14%2Fimage%20-p%20-S%20.%20%7C%20tar%20-xf%20-%20-C%20%2Fhome%2Fvmc%2FDesktop%2Fimx-yocto-bsp%2Fbuild-wayland%2Ftmp%2Fwork%2Fimx8mqevk-poky-linux%2Fbase-files%2F3.0.14%2Fpackage'%20returned%20non-zero%20exit%20status%202.%3C%2FMODULE%3E%3C%2FP%3E%3CP%3ESubprocess%20output%3A%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20bin%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'bin'.%3CBR%20%2F%3Etar%3A%20.%2Fusr%2Fbin%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20lib%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'lib'.%3CBR%20%2F%3Etar%3A%20.%2Fusr%2Flib%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20games%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'games'.%3CBR%20%2F%3Etar%3A%20.%2Fusr%2Fgames%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20share%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'share'.%3CBR%20%2F%3Etar%3A%20.%2Fusr%2Fshare%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20share%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'share'.%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20share%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'share'.%3CBR%20%2F%3Etar%3A%20.%2Fusr%2Fshare%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Etar%3A%20.%2Fusr%2Fshare%2Fdict%3A%20Cannot%20mkdir%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20share%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'share'.%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20share%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'share'.%3CBR%20%2F%3Etar%3A%20.%2Fusr%2Fshare%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Etar%3A%20.%2Fusr%2Fshare%2Fman%3A%20Cannot%20mkdir%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20share%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'share'.%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20share%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'share'.%3CBR%20%2F%3Etar%3A%20.%2Fusr%2Fshare%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Etar%3A%20.%2Fusr%2Fshare%2Fdoc%3A%20Cannot%20mkdir%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20share%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'share'.%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20share%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'share'.%3CBR%20%2F%3Etar%3A%20.%2Fusr%2Fshare%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Etar%3A%20.%2Fusr%2Fshare%2Fdoc%2Fbase-files-3.0.14%3A%20Cannot%20mkdir%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20share%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'share'.%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20share%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'share'.%3CBR%20%2F%3Etar%3A%20.%2Fusr%2Fshare%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Etar%3A%20.%2Fusr%2Fshare%2Fmisc%3A%20Cannot%20mkdir%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20share%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'share'.%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20share%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'share'.%3CBR%20%2F%3Etar%3A%20.%2Fusr%2Fshare%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Etar%3A%20.%2Fusr%2Fshare%2Fcommon-licenses%3A%20Cannot%20mkdir%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20share%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'share'.%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20share%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'share'.%3CBR%20%2F%3Etar%3A%20.%2Fusr%2Fshare%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Etar%3A%20.%2Fusr%2Fshare%2Finfo%3A%20Cannot%20mkdir%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20sbin%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'sbin'.%3CBR%20%2F%3Etar%3A%20.%2Fusr%2Fsbin%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20src%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'src'.%3CBR%20%2F%3Etar%3A%20.%2Fusr%2Fsrc%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20include%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'include'.%3CBR%20%2F%3Etar%3A%20.%2Fusr%2Finclude%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20tmp%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'tmp'.%3CBR%20%2F%3Etar%3A%20.%2Fvar%2Ftmp%3A%20Cannot%20create%20symlink%20to%20%E2%80%98volatile%2Ftmp%E2%80%99%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20local%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'local'.%3CBR%20%2F%3Etar%3A%20.%2Fvar%2Flocal%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20lib%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'lib'.%3CBR%20%2F%3Etar%3A%20.%2Fvar%2Flib%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20lib%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'lib'.%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20lib%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'lib'.%3CBR%20%2F%3Etar%3A%20.%2Fvar%2Flib%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Etar%3A%20.%2Fvar%2Flib%2Fmisc%3A%20Cannot%20mkdir%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20volatile%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'volatile'.%3CBR%20%2F%3Etar%3A%20.%2Fvar%2Fvolatile%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20volatile%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'volatile'.%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20volatile%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'volatile'.%3CBR%20%2F%3Etar%3A%20.%2Fvar%2Fvolatile%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Etar%3A%20.%2Fvar%2Fvolatile%2Ftmp%3A%20Cannot%20mkdir%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20volatile%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'volatile'.%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20volatile%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'volatile'.%3CBR%20%2F%3Etar%3A%20.%2Fvar%2Fvolatile%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Etar%3A%20.%2Fvar%2Fvolatile%2Flog%3A%20Cannot%20mkdir%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20log%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'log'.%3CBR%20%2F%3Etar%3A%20.%2Fvar%2Flog%3A%20Cannot%20create%20symlink%20to%20%E2%80%98volatile%2Flog%E2%80%99%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20lock%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'lock'.%3CBR%20%2F%3Etar%3A%20.%2Fvar%2Flock%3A%20Cannot%20open%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20spool%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'spool'.%3CBR%20%2F%3Etar%3A%20.%2Fvar%2Fspool%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20backups%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'backups'.%3CBR%20%2F%3Etar%3A%20.%2Fvar%2Fbackups%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20run%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'run'.%3CBR%20%2F%3Etar%3A%20.%2Fvar%2Frun%3A%20Cannot%20open%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20nsswitch.conf%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'nsswitch.conf'.%3CBR%20%2F%3Etar%3A%20.%2Fetc%2Fnsswitch.conf%3A%20Cannot%20open%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20hosts%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'hosts'.%3CBR%20%2F%3Etar%3A%20.%2Fetc%2Fhosts%3A%20Cannot%20open%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20issue.net%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'issue.net'.%3CBR%20%2F%3Etar%3A%20.%2Fetc%2Fissue.net%3A%20Cannot%20open%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20profile%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'profile'.%3CBR%20%2F%3Etar%3A%20.%2Fetc%2Fprofile%3A%20Cannot%20open%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20default%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'default'.%3CBR%20%2F%3Etar%3A%20.%2Fetc%2Fdefault%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20issue%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'issue'.%3CBR%20%2F%3Etar%3A%20.%2Fetc%2Fissue%3A%20Cannot%20open%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20skel%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'skel'.%3CBR%20%2F%3Etar%3A%20.%2Fetc%2Fskel%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20skel%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'skel'.%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20skel%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'skel'.%3CBR%20%2F%3Etar%3A%20.%2Fetc%2Fskel%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Etar%3A%20.%2Fetc%2Fskel%2F.profile%3A%20Cannot%20open%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20skel%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'skel'.%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20skel%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'skel'.%3CBR%20%2F%3Etar%3A%20.%2Fetc%2Fskel%3A%20Cannot%20mkdir%3A%20Bad%20address%3CBR%20%2F%3Etar%3A%20.%2Fetc%2Fskel%2F.bashrc%3A%20Cannot%20open%3A%20No%20such%20file%20or%20directory%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20mtab%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'mtab'.%3CBR%20%2F%3Etar%3A%20.%2Fetc%2Fmtab%3A%20Cannot%20open%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20hostname%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'hostname'.%3CBR%20%2F%3Etar%3A%20.%2Fetc%2Fhostname%3A%20Cannot%20open%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20fstab%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'fstab'.%3CBR%20%2F%3Etar%3A%20.%2Fetc%2Ffstab%3A%20Cannot%20open%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20shells%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'shells'.%3CBR%20%2F%3Etar%3A%20.%2Fetc%2Fshells%3A%20Cannot%20open%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20host.conf%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'host.conf'.%3CBR%20%2F%3Etar%3A%20.%2Fetc%2Fhost.conf%3A%20Cannot%20open%3A%20Bad%20address%3CBR%20%2F%3Egot%20*at()%20syscall%20for%20unknown%20directory%2C%20fd%204%3CBR%20%2F%3Eunknown%20base%20path%20for%20fd%204%2C%20path%20motd%3CBR%20%2F%3Ecouldn't%20allocate%20absolute%20path%20for%20'motd'.%3CBR%20%2F%3Etar%3A%20.%2Fetc%2Fmotd%3A%20Cannot%20open%3A%20Bad%20address%3CBR%20%2F%3Etar%3A%20Exiting%20with%20failure%20status%20due%20to%20previous%20errors%3C%2FP%3E%3CP%3EERROR%3A%20Logfile%20of%20failure%20stored%20in%3A%20%2Fhome%2Fvmc%2FDesktop%2Fimx-yocto-bsp%2Fbuild-wayland%2Ftmp%2Fwork%2Fimx8mqevk-poky-linux%2Fbase-files%2F3.0.14%2Ftemp%2Flog.do_package.1734591%3CBR%20%2F%3EERROR%3A%20Task%20(%2Fhome%2Fvmc%2FDesktop%2Fimx-yocto-bsp%2Fsources%2Fpoky%2Fmeta%2Frecipes-core%2Fbase-files%2Fbase-files_3.0.14.bb%3Ado_package)%20failed%20with%20exit%20code%20'1'%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2398533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20base-files%20error%20when%20build%20the%20yocto%20linux%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2398533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThanks%20u.%20It%20actived%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2398525%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20base-files%20error%20when%20build%20the%20yocto%20linux%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2398525%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EOn%20your%20ubuntu%20PC%2C%20run%20the%20command%26nbsp%3B%22sudo%20apt%20install%20tar%3D1.34%2Bdfsg-1build3%22%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
