adding browser package to using ltib
admin
Specialist II
hi all, i am trying to add  arora browser to my package list and compile it as a individual application. when i tried ltib -m prep arora
 --> Cannot find spec file that contains the package name arora.
If necessary please give the whole spec file name (with the .spec extension).
here is my spec file(arora.spec).
%define pfx /opt/freescale/rootfs/%{_target_cpu}
Summary         : Arora web browser
Version         : 0.10.2
Release         : 1
License         : GPL
Vendor          : Freescale
Packager        : xmanxxx
Group           : /usr/share/doc/rpm-/arora
URL             : http://xxxx
Source          : arora-0.10.2.tar.gz
BuildRoot       : %{_tmppath}/%{name}
Prefix          : %{pfx}
.... rest is same as template spec.
can anybody tell me wht is missing
 thanks
manz
medina
I have the spec file in:
         ltib/dist/lfs-5.1/arora/arora.spec
I have the package file with the other packages.
And I add the package in those files:
        ltib/config/userspace/sysconfig.lkc
        ltib/config/userspace/packages.lkc
        ltib/dist/lfs-5.1/common/pkg_map
        ltib/dist/lfs-5.1/sysconfig/sysconfig.spec
Medina
fabio_estevam
Try as follows:
./ltib -p arora.spec -m prep
Fabio Estevam
admin
Specialist II
I have met the same problem.
If you use
it could work.
But  I want to know why "./ltib -p arora -m prep" can not work.
