add linking with flash code
wowfoot
I'm making RF+SAM+CCID reader with PN7462.
I start with sw368431 example DoorAccess, and add CCID code from PN7462AU_ex_phExCcid_mcux.
compiling OK
linking Error.
    ./src/phExCcid_UsbUser.o: in function `phExCcid_Usbd_CCID_Init':
    phExCcid_UsbUser.c:222: undefined reference to `mwCCID_init'
mwCCID_init function is in mw_usbd_cciduser.c (The code is already in flash)
I added CCID folder to phExDoorAccess\mcux\DebugPN7462AU\PN7462AU\external\CCID from PN7462AU_ex_phExCcid_mcux, but the files look grayed in project explorer.
How can I link with flash code?
How can I remove grayed condition in project explorer?
KaiLi
Hello @wowfoot
Thanks for contacting us and interested in the NXP products. Based on your description of the issue, the following steps could help you.
To update this case, you may reply by email.
To provide confidential information or attachments, you may add that online.
Please login to our NXP technical support portal:
https://support.nxp.com/s/case/5002p00002qYTflAAG
The portal allows access to the full details of the case, including the previous communication.
Thank you for your interest in NXP Semiconductor products and for the opportunity to serve you.
Kelly
Technical Support
NXP Semiconductor
