Yocto mickledore Bluetooth bringup
2,203 次查看
PavanNittala
I am not able to bring up bluetooth on imx8mm-c2 board ,  I am using AMPAK firmware BCM4362A2_001.003.006.1132.1255.hcd , this is my dts file change
&uart3 { /* BT */
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_uart3>;
assigned-clocks = <&clk IMX8MMN(CLK_UART3)>;
assigned-clock-parents = <&clk IMX8MMN(SYS_PLL1_80M)>;
uart-has-rtscts;
status = "okay";
bluetooth {
compatible = "brcm,bcm43438-bt";
enable-gpios = GP_BT_ENABLE;
max-speed = <3000000>;
[ 186.437564] Bluetooth: HCI UART driver ver 2.3
[ 186.442064] Bluetooth: HCI UART protocol H4 registered
[ 186.447244] Bluetooth: HCI UART protocol BCSP registered
[ 186.452582] Bluetooth: HCI UART protocol ATH3K registered
[ 186.458350] Bluetooth: HCI UART protocol Broadcom registered
[ 186.458475] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
[ 186.464121] Bluetooth: HCI UART protocol QCA registered
[ 186.471653] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
[ 186.484319] hci_uart_bcm serial0-0: No reset resource, using default baud rate
[ 188.734730] Bluetooth: hci0: command 0x0c03 tx timeout
[ 196.830734] Bluetooth: hci0: BCM: Reset failed (-110)
root@nitrogen8mm:~# hciconfig
hci0: Type: Primary Bus: UART
BD Address: 00:00:00:00:00:00 ACL MTU: 0:0 SCO MTU: 0:0
DOWN
RX bytes:0 acl:0 sco:0 events:0 errors:0
TX bytes:4 acl:0 sco:0 commands:1 errors:0
2,111 次查看
PavanNittala
Thanks to grok3, the new AI tool, i was able to resolve this . Now i have to bring down rfkill and up it again to make bluetooth work
+#if 0
pinctrl_uart3: uart3grp {
fsl,pins = <
MX8MMN(IOMUXC_ECSPI1_SCLK_UART3_DCE_RX, 0x140)
@@ -320,6 +321,17 @@ MX8MMN(IOMUXC_ECSPI1_MISO_UART3_DCE_CTS_B, 0x140)
MX8MMN(IOMUXC_NAND_DQS_GPIO3_IO14, 0x119)
+#else
+ pinctrl_uart3: uart3grp {
+ fsl,pins = <
+ MX8MM_IOMUXC_ECSPI1_SCLK_UART3_DCE_RX 0x49
+ MX8MM_IOMUXC_ECSPI1_MOSI_UART3_DCE_TX 0x49
+ MX8MM_IOMUXC_ECSPI1_SS0_UART3_DCE_RTS_B 0x49
+ MX8MM_IOMUXC_ECSPI1_MISO_UART3_DCE_CTS_B 0x49
+ MX8MM_IOMUXC_NAND_DQS_GPIO3_IO14 0x19 /* BT_REG_ON */
+#endif
+#if 0
&uart3 { /* BT */
@@ -1259,15 +1272,29 @@ &uart3 { /* BT */
uart-has-rtscts;
status = "okay";
-#if 1
- 1 {
+ bluetooth {
brcm,bt-pcm-int-params = [01 02 00 01 01];
max-speed = <2000000>;
-#endif
+#else
+&uart3 {
+ pinctrl-names = "default";
+ pinctrl-0 = <&pinctrl_uart3>;
+ assigned-clocks = <&clk IMX8MM_CLK_UART3>;
+ assigned-clock-parents = <&clk IMX8MM_SYS_PLL1_80M>;
+ uart-has-rtscts; /* Flow control for AP6275S */
+ status = "okay";
+ bluetooth {
+ compatible = "brcm,bcm43438-bt"; /* AP6275S */
+ max-speed = <3000000>;
+ shutdown-gpios = <&gpio3 14 GPIO_ACTIVE_HIGH>; /* BT_REG_ON */
+#endif
4 回复数
2,112 次查看
PavanNittala
+#if 0
fsl,pins = <
+#else
+ fsl,pins = <
+#endif
+#if 0
&uart3 { /* BT */
uart-has-rtscts;
status = "okay";
-#if 1
- 1 {
+ bluetooth {
-#endif
+#else
+&uart3 {
+ status = "okay";
+ bluetooth {
+#endif
2,163 次查看
PavanNittala
Hi @joanxie , Thanks for the reply ,  Vendor asked to check using Scope which i don't have at the moment.
Some more info below , i am not able to see /dev/ttymxc2 , I think that's the issue ??
root@nitrogen8mm:~# dmesg |grep -iE 'tty'
[ 0.000000] Kernel command line: console=ttymxc1,115200 consoleblank=0 rootwait fixrtc root=/dev/mmcblk0p2 snd.slots=,snd-soc-imx-hdmi
[ 0.090110] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 185, base_baud = 5000000) is a IMX
[ 0.090237] serial serial0: tty port ttymxc2 registered
[ 0.090740] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 186, base_baud = 1500000) is a IMX
[ 0.821277] printk: console [ttymxc1] enabled
2,145 次查看
joanxie
you can use ls /dev/ttymxc* to check, and to confirm if you load the module correctly or not, pls refer to the link as below as reference
Bluetooth NXP UART Driver Linux BSP 6.1.22 btnxpuart - NXP Community
2,177 次查看
joanxie
refer to the log, maybe this issue is related to your module, did you contact the BT vendor to double confirm this?
%3CLINGO-SUB%20id%3D%22lingo-sub-2043109%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EYocto%20mickledore%20%E8%93%9D%E7%89%99%E5%90%AF%E5%8A%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2043109%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%97%A0%E6%B3%95%E5%9C%A8%20imx8mm-c2%20%E6%9D%BF%E4%B8%8A%E5%90%AF%E5%8A%A8%E8%93%9D%E7%89%99%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20AMPAK%20%E5%9B%BA%E4%BB%B6%20BCM4362A2_001.003.006.1132.1255.hcd%EF%BC%8C%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84%20dts%20%E6%96%87%E4%BB%B6%E6%9B%B4%E6%94%B9%3C%2FP%3E%3CP%3E%26amp%3Buart3%20%7B%20%2F*%20%E8%93%9D%E7%89%99%20*%2F%3CBR%20%2F%3E%20pinctrl%20%E5%90%8D%E7%A7%B0%20%3D%20%E2%80%9C%E9%BB%98%E8%AE%A4%E2%80%9D%EF%BC%9B%3CBR%20%2F%3E%20pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_uart3%26gt%3B%3B%3CBR%20%2F%3E%E5%88%86%E9%85%8D%E6%97%B6%E9%92%9F%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MMN(CLK_UART3)%26gt%3B%3B%3CBR%20%2F%3E%E5%88%86%E9%85%8D%E7%9A%84%E6%97%B6%E9%92%9F%E7%88%B6%E7%BA%A7%20%3D%20%26lt%3B%26amp%3Bclk%20IMX8MMN(SYS_PLL1_80M)%26gt%3B%3B%3CBR%20%2F%3E%20uart%20%E6%9C%89%20rtscts%EF%BC%9B%3CBR%20%2F%3E%E7%8A%B6%E6%80%81%20%3D%20%E2%80%9C%E5%A5%BD%E7%9A%84%E2%80%9D%3B%3C%2FP%3E%3CP%3E%E8%93%9D%E7%89%99%20%7B%3CBR%20%2F%3E%E5%85%BC%E5%AE%B9%3D%E2%80%9Cbrcm%EF%BC%8Cbcm43438-bt%E2%80%9D%EF%BC%9B%3CBR%20%2F%3E%E5%90%AF%E7%94%A8gpios%3DGP_BT_ENABLE%EF%BC%9B%3CBR%20%2F%3E%E6%9C%80%E5%A4%A7%E9%80%9F%E5%BA%A6%3D%26lt%3B3000000%26gt%3B%EF%BC%9B%3CBR%20%2F%3E%20%7D%3B%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3E%5B186.437564%5D%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%89%88%E6%9C%AC2.3%3CBR%20%2F%3E%20%5B186.442064%5D%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%E5%8D%8F%E8%AE%AEH4%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B186.447244%5D%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%E5%8D%8F%E8%AE%AEBCSP%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B186.452582%5D%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%E5%8D%8F%E8%AE%AEATH3K%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B186.458350%5D%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%E5%8D%8F%E8%AE%AEBroadcom%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B186.458475%5Dhci_uart_bcm%20serial0-0%3A%E6%9C%AA%E6%89%BE%E5%88%B0%E7%94%B5%E6%BA%90vbat%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E8%B0%83%E8%8A%82%E5%99%A8%3CBR%20%2F%3E%5B186.464121%5D%E8%93%9D%E7%89%99%EF%BC%9AHCI%20UART%E5%8D%8F%E8%AE%AEQCA%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B186.471653%5Dhci_uart_bcm%20serial0-0%3A%E6%9C%AA%E6%89%BE%E5%88%B0%E7%94%B5%E6%BA%90vddio%EF%BC%8C%E4%BD%BF%E7%94%A8%E8%99%9A%E6%8B%9F%E8%B0%83%E8%8A%82%E5%99%A8%3CBR%20%2F%3E%5B186.484319%5Dhci_uart_bcm%20serial0-0%3A%E6%97%A0%E5%A4%8D%E4%BD%8D%E8%B5%84%E6%BA%90%EF%BC%8C%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E6%B3%A2%E7%89%B9%E7%8E%87%3CBR%20%2F%3E%5B188.734730%5D%E8%93%9D%E7%89%99%EF%BC%9Ahci0%EF%BC%9A%E5%91%BD%E4%BB%A40x0c03%20tx%E8%B6%85%E6%97%B6%3CBR%20%2F%3E%5B196.830734%5D%E8%93%9D%E7%89%99%EF%BC%9Ahci0%EF%BC%9ABCM%EF%BC%9A%E9%87%8D%E7%BD%AE%E5%A4%B1%E8%B4%A5%EF%BC%88-110%EF%BC%89%3C%2FP%3E%3CP%3Eroot%40nitrogen8mm%3A~%23%20hciconfig%3CBR%20%2F%3E%20hci0%EF%BC%9A%E7%B1%BB%E5%9E%8B%EF%BC%9A%E4%B8%BB%E6%80%BB%E7%BA%BF%EF%BC%9AUART%3CBR%20%2F%3E%20BD%20%E5%9C%B0%E5%9D%80%EF%BC%9A00%3A00%3A00%3A00%3A00%3A00%20ACL%20MTU%EF%BC%9A0%3A0%20SCO%20MTU%EF%BC%9A0%3A0%3CBR%20%2F%3E%E5%90%91%E4%B8%8B%3CBR%20%2F%3ERX%E5%AD%97%E8%8A%82%EF%BC%9A0%20acl%EF%BC%9A0%20sco%EF%BC%9A0%20%E4%BA%8B%E4%BB%B6%EF%BC%9A0%20%E9%94%99%E8%AF%AF%EF%BC%9A0%3CBR%20%2F%3E%20TX%20%E5%AD%97%E8%8A%82%EF%BC%9A4%20acl%EF%BC%9A0%20sco%EF%BC%9A0%20%E5%91%BD%E4%BB%A4%EF%BC%9A1%20%E9%94%99%E8%AF%AF%EF%BC%9A0%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2046941%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AYocto%20mickledore%20%E8%93%9D%E7%89%99%E5%90%AF%E5%8A%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2046941%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%3CSPAN%3Els%20%2Fdev%2Fttymxc*%20%E6%9D%A5%E6%A3%80%E6%9F%A5%EF%BC%8C%E5%B9%B6%E7%A1%AE%E8%AE%A4%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%E5%8A%A0%E8%BD%BD%E6%A8%A1%E5%9D%97%EF%BC%8C%E8%AF%B7%E5%8F%82%E8%80%83%E4%B8%8B%E9%9D%A2%E7%9A%84%E9%93%BE%E6%8E%A5%E4%BD%9C%E4%B8%BA%E5%8F%82%E8%80%83%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FBluetooth-NXP-UART-Driver-Linux-BSP-6-1-22-btnxpuart%2Fta-p%2F1708588%22%20target%3D%22_blank%22%3E%E8%93%9D%E7%89%99%20NXP%20UART%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%20Linux%20BSP%206.1.22btnxpuart%20-%20NXP%20%E7%A4%BE%E5%8C%BA%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2045224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AYocto%20mickledore%20%E8%93%9D%E7%89%99%E5%90%AF%E5%8A%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2045224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F39586%22%20target%3D%22_blank%22%3E%40joanxie%3C%2FA%3E%20%EF%BC%8C%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E5%A4%8D%EF%BC%8C%E4%BE%9B%E5%BA%94%E5%95%86%E8%A6%81%E6%B1%82%E4%BD%BF%E7%94%A8%20Scope%20%E8%BF%9B%E8%A1%8C%E6%A3%80%E6%9F%A5%EF%BC%8C%E4%BD%86%E6%88%91%E7%9B%AE%E5%89%8D%E6%B2%A1%E6%9C%89%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%8B%E9%9D%A2%E8%BF%98%E6%9C%89%E4%B8%80%E4%BA%9B%E4%BF%A1%E6%81%AF%EF%BC%8C%E6%88%91%E7%9C%8B%E4%B8%8D%E5%88%B0%20%2Fdev%2Fttymxc2%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E5%B0%B1%E6%98%AF%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%EF%BC%9F%EF%BC%9F%3C%2FP%3E%3CP%3Eroot%40nitrogen8mm%3A~%23%20dmesg%20%7Cgrep%20-iE%20'tty'%3CBR%20%2F%3E%20%5B0.000000%5D%E5%86%85%E6%A0%B8%E5%91%BD%E4%BB%A4%E8%A1%8C%EF%BC%9Aconsole%3Dttymxc1%2C115200%20consoleblank%3D0%20rootwait%20fixrtc%20root%3D%2Fdev%2Fmmcblk0p2%20snd.slots%3D%EF%BC%8Csnd-soc-imx-hdmi%3CBR%20%2F%3E%20%5B0.090110%5D30880000.%E5%BA%8F%E5%88%97%E5%8F%B7%EF%BC%9Attymxc2%20%E4%BD%8D%E4%BA%8E%20MMIO%200x30880000%20(irq%20%3D%20185%2C%20base_baud%20%3D%205000000)%20%E6%98%AF%20IMX%3CBR%20%2F%3E%20%5B0.090237%5D%E4%B8%B2%E8%A1%8Cserial0%3Atty%E7%AB%AF%E5%8F%A3ttymxc2%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B0.090740%5D30890000.%E5%BA%8F%E5%88%97%E5%8F%B7%EF%BC%9Attymxc1%20%E4%BD%8D%E4%BA%8E%20MMIO%200x30890000%20(irq%20%3D%20186%2C%20base_baud%20%3D%201500000)%20%E6%98%AF%20IMX%3CBR%20%2F%3E%20%5B0.821277%5Dprintk%3A%E6%8E%A7%E5%88%B6%E5%8F%B0%5Bttymxc1%5D%E5%B7%B2%E5%90%AF%E7%94%A8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2044483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AYocto%20mickledore%20%E8%93%9D%E7%89%99%E5%90%AF%E5%8A%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2044483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%8F%82%E8%80%83%E6%97%A5%E5%BF%97%EF%BC%8C%E4%B9%9F%E8%AE%B8%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E4%B8%8E%E6%82%A8%E7%9A%84%E6%A8%A1%E5%9D%97%E6%9C%89%E5%85%B3%EF%BC%8C%E6%82%A8%E6%98%AF%E5%90%A6%E8%81%94%E7%B3%BB%E8%BF%87%20BT%20%E4%BE%9B%E5%BA%94%E5%95%86%E6%9D%A5%E5%86%8D%E6%AC%A1%E7%A1%AE%E8%AE%A4%E8%BF%99%E4%B8%80%E7%82%B9%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
