Which Scheduler Algorithm SJA1105S support
3,575 次查看
ramesh_mali
I am working on SJA1105S ethernet switch.
I want know which port scheduler algorithm this switch supports.
ramesh
4 回复数
3,414 次查看
ramesh_mali
Thanks for the reply.
I would like to know, whether SJA1105S chip has register bit supports for this. Because in configuration I have parameter for Scheduler Algorithms Types as -1) Deficit Round Robin 2) Strict Priority 3) Weighted Round Robin.
So how do i configure switch to work according to selected scheduler algorithm types.
Ramesh
3,414 次查看
ufedor
The only scheduling algorithms supported by the SJA1105 are Strict Priority and Credit Based Shaping with a total of 16 AVB queues which can be assigned to the 4 ports. There is no round-robin scheduling algorithm between the priority queues, but some fairness and bandwidth reservation can be attained by using CBS.
3,414 次查看
ramesh_mali
Thank you for your kind information
Ramesh
3,411 次查看
ufedor
Please refer to the attached document.
