What is "single_model_DK_tech" library invoked while working with ADS and LDMOS Models? where do we get it?
saurabhnerkar
#Ldmos_Model_libraries
While working with MRF24300N ldmos library in ADS, the system doesn't work. It says "Single_model_dk_tech" library is not open.
andrei_skok
Please look at the https://www.nxp.com/files-static/abstract/ldmos_models/OVERVIEW_MDL_ADS_DESIGN_KIT.pdf
Question:
After ADS2014 and later is open, the desired Product Model Design Kit is in the schematic palette, but an error message appears : Failed to get data for library “Single_Model_DK_tech
Answer:
This error message is caused by a library naming issue in previous versions for ADS. This error does
not cause any model performance or circuit simulation issues and should be ignored
Andrei
andrei_skok
Question:
Answer:
Andrei
saurabhnerkar
Thank you very much for your answer, sir!
