WCT-15WTXAUTO NFC function
Chaoran_Li
Open the FreeMASTER project file WCH and NFC SW Tool.pmp, The home screen will show some error. And NFC will not work.
I looked at the WPC manual and needed the map file *.elf to run wct1013A_MPA9.pmp.
⇒Can you please provide the *.elf file for the WCH and NFC SW Tool.pmp?
