Using Raspberry Pi CM4 to drive PN7150
839 次查看
yaohui
Hello everyone
I use PN7150 to connect to Raspberry Pi CM4
My current pin settings
SCL SCL-I2C1
SDA   SDA-I2C1
IRQ    GPIO-24
VEN   GPIO-25
GND  GND
Vbat  3.3V
VCC   3.3V
But I don’t quite understand the part about setting the Device tree for Rarpberry Pi 3 (reference document AN11697 3.2.3.1)
Can you provide the setup process for Raspberry Pi CM4? Thank you
标记 (1)
814 次查看
gaurav_sharma
Hi @yaohui ,
Please go through AN11758 PN7150 Raspberry Pi SBC kit quick start guide
