UUU tool flashing
UUU tool flashing
2,534 次查看
Tanushree
We are using Imx8dxl as a host processor. i am trig to flash the UUU tool. I am getting an TIMEOUT ERROR. And attached the log below.
file:///tmp/pid-3577/usb_console_prints.png
3 回复数
2,523 次查看
Manuel_Salas
Hello @Tanushree
Could you please give more details?
The steps to flash your boards, what BSP you are using, etc.
Also, the logs were not atteched.
Best regards.
Salas.
2,503 次查看
Tanushree
Hello @Manuel_Salas
Any package is needed to use the UUU tool because some Ubuntu's is working.Attached the ERROR log below
2,486 次查看
Manuel_Salas
Hello @Tanushree
You can try to update your UUU tools to the last version.
Also, please be sure your board is in download serial mode with uuu -lsusb command.
Best regards.
Salas.
