UUU tool flashing
UUU tool flashing
Tanushree
We are using Imx8dxl as a host processor. i am trig to flash the UUU tool. I am getting an TIMEOUT ERROR. And attached the log below.
file:///tmp/pid-3577/usb_console_prints.png
Manuel_Salas
Hello @Tanushree
Could you please give more details?
The steps to flash your boards, what BSP you are using, etc.
Also, the logs were not atteched.
Best regards.
Salas.
Tanushree
Hello @Manuel_Salas
Any package is needed to use the UUU tool because some Ubuntu's is working.Attached the ERROR log below
Manuel_Salas
Hello @Tanushree
You can try to update your UUU tools to the last version.
Also, please be sure your board is in download serial mode with uuu -lsusb command.
Best regards.
Salas.
