Tutoriales de FRDM-KL46Z
4,550 次查看
acmr
Help meee..!!
Tutoriales, ejemplos o algún sitio que me ayude a utilizar mi tarjeta FRDM-KL46Z. En especial como utilizar el LCD de dicho microconntrolador.
Saludos!
7 回复数
3,630 次查看
Amit_Kumar1
Senior Contributor II
Hi Ana
I think u r looking for some basic tutorials to interface LCD in FRDM-KL46 board.
You can Check this link for that. For Pinouts of LCD,
using the above sheet u can configure the 7 Segment displays to display any digit. Here A,B,C,D,E,F,G  are the 7 segments and 1,2,3,4 are the 4 Digits present in the LCD so using the combinations on the pins u can display digits, decimal(.) and colon(:)  . Hope this helps.
Amit
3,630 次查看
acmr
Gracias
3,630 次查看
BlackNight
3,630 次查看
mjbcswitzerland
Specialist V
3,630 次查看
acmr
Gracias
3,630 次查看
kerryzhou
Hi Ana Celia Medina Rocha,
       Could please rewrite your quesiton in English? Then we can help you solved it.
Jingjing
3,630 次查看
acmr
:smileywink:
Can you help me with information or tutorials about the operation of FRDM-KL46Z´s LCD
