TJA1145 Partical Network Wakeup by error frame(Bit Error)
2,839件の閲覧回数
1090097669
Partial network wake-up ID function in TJA145T chip:
     The current question is: before the chip is Sleep Mode, there is a problem in configuring the corresponding register, so that the chip not only detects the corresponding fixed Length ,ID and Signal,
And the Error Frame is detected and the error count is entered. After the count is exceeded, the chip is erroneously awakened, causing the program to run abnormally.
ラベル(2)
