TJA1043T Isolation system reference design
2,905件の閲覧回数
RheaGao
Hi ,I want to use CAN with wake up all the way and CHOOSE TJA1043T, but my system is an isolation system and adopts optical coupling isolation. I would like to ask how to deal with the power supply of THE Vio pins of TJA1043.  Is it connected to the VCC?  Is there a TJA1043 isolation design for reference?  Thank you very much!
2,899件の閲覧回数
guoweisun
3 返答(返信)
2,893件の閲覧回数
guoweisun
TJA1043 can't get the ground isolation between RX/TX and CANH/L.
2,900件の閲覧回数
guoweisun
You can select TJA1052I for isolation application.
TJA1052i Galvanically isolated high-speed CAN transceiver (nxp.com.cn)
2,895件の閲覧回数
RheaGao
Hi,I have seen the product TJA1052i, but I want to confirm whether TJA1043T can be used in isolation system?
