Symphony Studio under Win XP and path separators
1,805件の閲覧回数
schi
It seems as if there is a path separators issue within symphony studio: The build process through the eclipse interface seems to delete single backslash \ path separators while unix-style separators / work fine.
While this is strange for a windows environment, it is even worse as the browse feature generate path names with single backslashes, so manual editing is required...
Any solution out there?
1,301件の閲覧回数
RandallAiken
Apparently,  "\\"  also works.   Just browse and select your file, and then add an extra "\" to each path separator.
Message Edited by RandallAiken on 2008-10-22 02:06 AM
