Symphony Soundbite beginners problems
2,391件の閲覧回数
MalkContent
I've been handed a Symphony Soundbite Kit from the university and am supposed to make it run some signal altering methods on audio signals.
I've got years of expirience in coding and I've got a basic knowledge of how microcontrollers etc. work, but I never actually coded for one.
My problem now is, that I don't know how to address the pins for input/output.
I've looked through some tutorials, the most helpful being the c# tutorial, but I still don't know, how to get to the pins.
If possible I'd like to start from the scratch, so I can get a better understanding of how this works.
Thanks for anything :smileyhappy:
3 返答(返信)
1,587件の閲覧回数
MalkContent
thanks for the advice and sorry for the huge huge delay but I had some major troubles with the rest of my life.
As for the assembly project template:
I tried modifying the process_audio so it'd give a 20db boost to the input before putting it through, just as a small excercise.
Well... I'm having only minor issues understanding the code, but major issues writing some on my own.
For istance I can't find the MUL equivalent.
Is there a manual for the freescale assembly instructions anywhere?
I'm a bit upset about how hard it is to get to the point of what I actually wanna do.
All I need is to find out in what form the dsp gets it's input, take it and put it into the good old  fft :smileysad:
1,587件の閲覧回数
clangen
sorry for the delay - I don't observe this forum on a daily basis...
The documentation for the DSP563xx family is here:
http://cache.freescale.com/files/dsp/doc/ref_manual/DSP56300FM.pdf?fpsp=1&WT_TYPE=Reference Manuals&WT_VENDOR=FREESCALE&WT_FILE_FORMAT=pdf&WT_ASSET=Documentation
the manual for the DSP56371:
http://cache.freescale.com/files/dsp/doc/user_guide/DSP56371UM.pdf?fpsp=1&WT_TYPE=Users Guides&WT_VENDOR=FREESCALE&WT_FILE_FORMAT=pdf&WT_ASSET=Documentation
There are a couple of manuals for the SoundBite board but no specific tutorial unfortunately.
Please have a look to
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=DSP56371&fpsp=1&tab=Documentation_Tab
and
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=SYMP_SOUNDBITE&fpsp=1&tab=Documentati...
for the documentaion for the DSO56371 and the Symphony SoundBite board.
To answer your question. There is no 'MUL' instruction. The multiplication is done by the 'mpy' instruction
  mpy x1,y1,a      ; multiplies the register contents of x1 by the content of y1 and stores the result in the accumulator a.
Anyway learning DSP programming takes a one semester course that should be accompanied by another one semester course doing DSP projects - just to get started.
Curently I'm looking for a good textbook to support my students' work. maybe I've to write it by myself :smileywink:.
Christian
1,587件の閲覧回数
clangen
you can find the examples here:
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=SYMP_SOUNDBITE&fsrch=1
please use the assembly template to start your own coding experiments.
Christian
