Starting with MC1321X
2,384 次查看
Steelheart
Pleas help... i m very new to code warrior... can any please help with hardware and software aspect of MC1321X ...communication b/w a node and coordinator and to program the coordinator... am i supposed to buy complete module or just the MC1321X chip and design it on PCB....also is it possible to code MC1321 with evaluation pack or i have to download the complete pro version...please help me with some ebooks and links if possible..i will be highly grateful...
1,655 次查看
addiyi
You should start, by order a ZigBee development kit, install BeeKit (witch contain three ZigBee stack: SMAC, MAC and BeeStack). You will find a lot of useful documentation (after install BeeKit, in \Documentation folder) and this will help you to select the codebase that you need and to undestand how ZigBee works. Also, BeeKit provide a lot of demo application designed to help you.  More information on: www.freescale.com/zigbee
Depend of what application have in mind, you can use CW Special Edition (limited at 32K code) or other CW version.
Adrian
1,656 次查看
addiyi
Adrian
