Single ended input on the CBTL04083BBS
gompertz
Hi, I am curious if it is possible to use a single ended input on the CBTL04083BBS? The CBTL04083BBS is a 4-circuit differential-channel multiplexer; however one of my inputs is single-ended (not differential). Can I feed it into the N or P on one of the lanes and leave the other floating?
Thank you!
guoweisun
If you use single signal why do you want to select CBTL04083BBS?
For transfer signal use one channel ,that should be no problem.
