Simple Gui Guider Question
1,560 次查看
GeoffW123
Hello
Just downloaded and been experimenting with Gui Guider. Nice App, looks very impressive. However I want to use LVGL V8.x.x. It would appear that Gui Guider is outputting V7.x.x version code.
Have NXP plans to update Gui Guider to LVGL version 8.x.x,  and if so when is it estimated to be available ?  Thanks
1,540 次查看
GeoffW123
Thanks for the reply. LVGL Version 8 has changed quite a bit from Version 7, so manually converting is not an quick or easy task.
If you can pass on that you have already had a user request to provide an option for version 8 output, it might encourage that work to be done.
1,544 次查看
jingpan
Hi @GeoffW123 ,
Yes, NXP will update this tool and LVGL library occasionally. But there isn't a fixed upgrade plan.
Jing
