SWUpdate with quashfs on eMMC
914件の閲覧回数
alanlow
I managed to add swupdate to imx8mm-evk imx-linux system kernel 5.10.72 and use swupdate-scripts to generate the base image and update image. The images work for rootfs with ext2, ext3 and ext4. However, I need rootfs to use squashfs instead but seems like the swupdate-script does not support squashfs?
Would appreciate if you can provide some lights on creating the base image which rootfs is squashfs fstype for imx8mm.
Thanks!
0 返答(返信)
