SDXC in LS1012AXN7EKB
1,803 次查看
sowmiya_a
LS1012AXN7EKB - Will this part support 128 GB of sd card (SDXC)
4 回复数
1,795 次查看
mrudangshelat-13
Hi @sowmiya_a,
LS1012A is compatible with the SD memory card specification version 3.01 and supports the high-capacity SD memory card which means it will support SDXC.
Mrudang Shelat
1,790 次查看
sowmiya_a
Hi @mrudangshelat-13
Based on your response my understanding is that LS1012AXN7EKB can support 128 GB capacity SD card (SDXC). Is my understanding correct?
Sowmiya
1,773 次查看
mrudangshelat-13
破坏者
Hi @sowmiya_a,
As per the LS1012A reference manual, it supports standard, high and extended capacity card types which means it will support upto 2TB.
For more information regarding SD memory card specification version 3.01, please refer to this link.
Mrudang
1,770 次查看
sowmiya_a
Thanks for the confirmation @mrudangshelat-13
