SD Card Support By LS1012AXN7EKB
1,009 次查看
Jigs
Is LS1012AXN7EKB supports 128 GB capacity SD card (SDXC) ?
987 次查看
yipingwang
Yes, LS1012A supports UHS-I modes. As you know, the SDXC is accessed using block mode. However, SDR104 mode only support up to 125 Mhz.
988 次查看
yipingwang
