SC16IS752 IRQ Pull-Up Resistor value
已解决
跳至解决方案
1,000 次查看
timbeyer
In the data sheet for SC16IS752 (and even SC16IS750) the IRQ Pull-Up Resistor value is recommended 1 kOhm for 3.3 V supply. What is the cause ? What will occur with a pullup as high as 33 kOhm ? There is no value given for the leakage current (for GPIO it's 1 µA, for SPI it's 10 µA).
We design a low power circuit with a quite long interrupt response time and would not spend 3.3 mA over several seconds when the rest of the circuit runs on 2 mA.
1 解答
981 次查看
JozefKozon
Dear Tim,
Why 1 kΩ is recommended?
  1. Fast rise time for IRQ signal
    The IRQ pin is an open-drain output, so the pull-up resistor determines how quickly the line goes high after the device releases it.
    • With 1 kΩ at 3.3 V, the current is about 3.3 mA when the pin is low, which ensures a strong pull-up and a fast transition when released.
    • This is important because IRQ signals often need to meet timing specs for SPI/I²C or interrupt controllers.
  2. Noise immunity
    A strong pull-up reduces susceptibility to noise and ensures the voltage reaches a valid logic high quickly, even with some parasitic capacitance on the line.
What happens with 33 kΩ?
  • Rise time increases significantly because the RC time constant grows: τ=R×C\tau = R \times Cτ=R×C If the line has, say, 50 pF of capacitance:
    • With 1 kΩ: τ=1,000×50pF=50ns\tau = 1{,}000 \times 50 \text{pF} = 50 \text{ns}τ=1,000×50pF=50ns
    • With 33 kΩ: τ=33,000×50pF=1.65µs\tau = 33{,}000 \times 50 \text{pF} = 1.65 \text{µs}τ=33,000×50pF=1.65µs That’s still fast for many systems, but if your interrupt latency is long and the MCU samples asynchronously, it might not matter much.
  • Logic level stability: With higher resistance, leakage currents (up to 10 µA for SPI pins) could cause noticeable voltage drop. The IRQ might only reach ~3.0 V instead of 3.3 V, which is usually okay but could be marginal in noisy environments.
  • If your interrupt response time is in milliseconds and you can tolerate slower rise times, 33 kΩ is likely fine.
  • Just ensure:
    • Total bus capacitance isn’t huge.
    • Leakage currents don’t pull the line below VIH (usually >2 V for 3.3 V logic).
With Best Regards,
Jozef
在原帖中查看解决方案
1 回复
982 次查看
JozefKozon
Dear Tim,
  2. Noise immunity
  • Just ensure:
With Best Regards,
Jozef
%3CLINGO-SUB%20id%3D%22lingo-sub-2180503%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESC16IS752%20IRQ%20%E4%B8%8A%E6%8B%89%E7%94%B5%E9%98%BB%E5%80%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2180503%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%9C%A8%20SC16IS752%EF%BC%88%E7%94%9A%E8%87%B3%20SC16IS750%EF%BC%89%E7%9A%84%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%B8%AD%EF%BC%8C%E5%AF%B9%E4%BA%8E%203.3%20V%20%E7%94%B5%E6%BA%90%EF%BC%8CIRQ%20%E4%B8%8A%E6%8B%89%E7%94%B5%E9%98%BB%E7%9A%84%E6%8E%A8%E8%8D%90%E5%80%BC%E4%B8%BA%201%20kOhm%E3%80%82%E5%8E%9F%E5%9B%A0%E4%BD%95%E5%9C%A8%EF%BC%9F%E4%B8%8A%E6%8B%89%E8%87%B3%2033%20kOhm%20%E6%97%B6%E4%BC%9A%E5%8F%91%E7%94%9F%E4%BB%80%E4%B9%88%E6%83%85%E5%86%B5%EF%BC%9F%E6%B2%A1%E6%9C%89%E7%BB%99%E5%87%BA%E6%BC%8F%E7%94%B5%E6%B5%81%E7%9A%84%E5%80%BC%EF%BC%88GPIO%20%E4%B8%BA%201%20%C2%B5A%EF%BC%8CSPI%20%E4%B8%BA%2010%20%C2%B5A%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E8%AE%BE%E8%AE%A1%E7%9A%84%E4%BD%8E%E5%8A%9F%E8%80%97%E7%94%B5%E8%B7%AF%E5%85%B7%E6%9C%89%E7%9B%B8%E5%BD%93%E9%95%BF%E7%9A%84%E4%B8%AD%E6%96%AD%E5%93%8D%E5%BA%94%E6%97%B6%E9%97%B4%EF%BC%8C%E5%BD%93%E7%94%B5%E8%B7%AF%E7%9A%84%E5%85%B6%E4%BB%96%E9%83%A8%E5%88%86%E4%BB%A5%202%20mA%20%E7%94%B5%E6%B5%81%E8%BF%90%E8%A1%8C%E6%97%B6%EF%BC%8C%E4%B8%8D%E4%BC%9A%E5%9C%A8%E5%87%A0%E7%A7%92%E9%92%9F%E5%86%85%E8%80%97%E8%B4%B9%203.3%20mA%20%E7%94%B5%E6%B5%81%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2180531%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SC16IS752%20IRQ%20Pull-Up%20Resistor%20value%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2180531%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%E8%92%82%E5%A7%86%3C%2FP%3E%0A%3CH3%20id%3D%22toc-hId-1976446301%22%20id%3D%22toc-hId-1999655540%22%3E%E4%B8%BA%E4%BB%80%E4%B9%88%E5%BB%BA%E8%AE%AE%E4%BD%BF%E7%94%A8%201%20k%CE%A9%EF%BC%9F%3C%2FH3%3E%0A%3COL%3E%0A%3CLI%3E%0A%3CP%3EIRQ%20%E4%BF%A1%E5%8F%B7%3CBR%20%2F%3E%E7%9A%84%E5%BF%AB%E9%80%9F%E4%B8%8A%E5%8D%87%E6%97%B6%E9%97%B4%20IRQ%20%E5%BC%95%E8%84%9A%E6%98%AF%E5%BC%80%E6%BC%8F%E8%BE%93%E5%87%BA%EF%BC%8C%E5%9B%A0%E6%AD%A4%E4%B8%8A%E6%8B%89%E7%94%B5%E9%98%BB%E5%86%B3%E5%AE%9A%E4%BA%86%E8%AE%BE%E5%A4%87%E7%89%88%E6%9C%AC%E5%90%8E%E7%BA%BF%E8%B7%AF%E5%8F%98%E9%AB%98%E7%9A%84%E9%80%9F%E5%BA%A6%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E5%9C%A8%203.3%20V%20%E6%97%B6%E4%B8%BA%201%20k%CE%A9%EF%BC%8C%E5%BD%93%E5%BC%95%E8%84%9A%E5%A4%84%E4%BA%8E%E4%BD%8E%E7%94%B5%E5%B9%B3%E6%97%B6%EF%BC%8C%E7%94%B5%E6%B5%81%E7%BA%A6%E4%B8%BA%203.3%20mA%EF%BC%8C%E8%BF%99%E7%A1%AE%E4%BF%9D%E4%BA%86%E5%BC%BA%E5%8A%B2%E7%9A%84%E4%B8%8A%E6%8B%89%E5%92%8C%E7%89%88%E6%9C%AC%E6%97%B6%E7%9A%84%E5%BF%AB%E9%80%9F%E8%BF%87%E6%B8%A1%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E8%BF%99%E5%BE%88%E9%87%8D%E8%A6%81%EF%BC%8C%E5%9B%A0%E4%B8%BA%20IRQ%20%E4%BF%A1%E5%8F%B7%E9%80%9A%E5%B8%B8%E9%9C%80%E8%A6%81%E6%BB%A1%E8%B6%B3%20SPI%2FI%C2%B2C%20%E6%88%96%E4%B8%AD%E6%96%AD%E6%8E%A7%E5%88%B6%E5%99%A8%E7%9A%84%E5%AE%9A%E6%97%B6%E8%A7%84%E6%A0%BC%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%E6%8A%97%E5%99%AA%E6%80%A7%3CBR%20%2F%3E%E5%BC%BA%E5%A4%A7%E7%9A%84%E4%B8%8A%E6%8B%89%E5%8A%9F%E8%83%BD%E5%8F%AF%E9%99%8D%E4%BD%8E%E5%AF%B9%E5%99%AA%E5%A3%B0%E7%9A%84%E6%95%8F%E6%84%9F%E6%80%A7%EF%BC%8C%E5%B9%B6%E7%A1%AE%E4%BF%9D%E7%94%B5%E5%8E%8B%E5%BF%AB%E9%80%9F%E8%BE%BE%E5%88%B0%E6%9C%89%E6%95%88%E7%9A%84%E9%80%BB%E8%BE%91%E9%AB%98%E7%94%B5%E5%B9%B3%EF%BC%8C%E5%8D%B3%E4%BD%BF%E7%BA%BF%E8%B7%AF%E4%B8%8A%E5%AD%98%E5%9C%A8%E4%B8%80%E4%BA%9B%E5%AF%84%E7%94%9F%E7%94%B5%E5%AE%B9%E3%80%82%3C%2FP%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CH3%20id%3D%22toc-hId-168991838%22%20id%3D%22toc-hId-192201077%22%3E%3CSTRONG%3E33%20k%CE%A9%20%E4%BC%9A%E5%8F%91%E7%94%9F%E4%BB%80%E4%B9%88%E6%83%85%E5%86%B5%EF%BC%9F%3C%2FSTRONG%3E%3C%2FH3%3E%0A%3CUL%3E%0A%3CLI%3E%0A%3CP%3E%3CSTRONG%3E%E4%B8%8A%E5%8D%87%E6%97%B6%E9%97%B4%E4%BC%9A%E5%A4%A7%E5%B9%85%E5%A2%9E%E5%8A%A0%3C%2FSTRONG%3E%EF%BC%8C%E5%9B%A0%E4%B8%BA%20RC%20%E6%97%B6%E9%97%B4%E5%B8%B8%E6%95%B0%E4%BC%9A%E5%A2%9E%E9%95%BF%EF%BC%9A%20%3CSPAN%20class%3D%22math%20math-inline%22%3E%3CSPAN%20class%3D%22katex%22%3E%3CSPAN%20class%3D%22katex-mathml%22%3E%CF%84%3DR%C3%97C%5Ctau%20%3D%20R%20%5Ctimes%20C%3C%2FSPAN%3E%3CSPAN%20class%3D%22katex-html%22%3E%3CSPAN%20class%3D%22base%22%3E%3CSPAN%20class%3D%22mord%20mathnormal%22%3E%CF%84%3C%2FSPAN%3E%3CSPAN%20class%3D%22mrel%22%3E%3D%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22base%22%3E%3CSPAN%20class%3D%22mord%20mathnormal%22%3ER%3C%2FSPAN%3E%3CSPAN%20class%3D%22mbin%22%3E%C3%97%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22base%22%3E%3CSPAN%20class%3D%22mord%20mathnormal%22%3EC%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%E5%A6%82%E6%9E%9C%E7%BA%BF%E8%B7%AF%E7%9A%84%E7%94%B5%E5%AE%B9%E4%B8%BA%2050%20pF%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E1%20k%CE%A9%EF%BC%9A%20%3CSPAN%20class%3D%22math%20math-inline%22%3E%3CSPAN%20class%3D%22katex%22%3E%3CSPAN%20class%3D%22katex-mathml%22%3E%CF%84%3D1%2C000%C3%9750pF%3D50ns%5Ctau%20%3D%201%7B%2C%7D000%20%5Ctimes%2050%20%5Ctext%7BpF%7D%20%3D%2050%20%5Ctext%7Bns%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22katex-html%22%3E%3CSPAN%20class%3D%22base%22%3E%3CSPAN%20class%3D%22mord%20mathnormal%22%3E%CF%84%3C%2FSPAN%3E%3CSPAN%20class%3D%22mrel%22%3E%3D%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22base%22%3E%3CSPAN%20class%3D%22mord%22%3E1%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%22%3E%3CSPAN%20class%3D%22mpunct%22%3E%2C%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%22%3E000%3C%2FSPAN%3E%3CSPAN%20class%3D%22mbin%22%3E%C3%97%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22base%22%3E%3CSPAN%20class%3D%22mord%22%3E50%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%20text%22%3E%3CSPAN%20class%3D%22mord%22%3EpF%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22mrel%22%3E%3D%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22base%22%3E%3CSPAN%20class%3D%22mord%22%3E50%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%20text%22%3E%3CSPAN%20class%3D%22mord%22%3Ens%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%3E33%20k%CE%A9%EF%BC%9A%20%3CSPAN%20class%3D%22math%20math-inline%22%3E%3CSPAN%20class%3D%22katex%22%3E%3CSPAN%20class%3D%22katex-mathml%22%3E%CF%84%3D33%2C000%C3%9750pF%3D1.65%C2%B5s%5Ctau%20%3D%2033%7B%2C%7D000%20%5Ctimes%2050%20text%5C%7BpF%7D%20%3D%201.65%20%5Ctext%7B%C2%B5s%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22katex-html%22%3E%3CSPAN%20class%3D%22base%22%3E%3CSPAN%20class%3D%22mord%20mathnormal%22%3E%CF%84%3C%2FSPAN%3E%3CSPAN%20class%3D%22mrel%22%3E%3D%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22base%22%3E%3CSPAN%20class%3D%22mord%22%3E33%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%22%3E%3CSPAN%20class%3D%22mpunct%22%3E%2C%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%22%3E000%3C%2FSPAN%3E%3CSPAN%20class%3D%22mbin%22%3E%C3%97%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22base%22%3E%3CSPAN%20class%3D%22mord%22%3E50%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%20text%22%3E%3CSPAN%20class%3D%22mord%22%3EpF%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22mrel%22%3E%3D%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22base%22%3E%3CSPAN%20class%3D%22mord%22%3E1.65%3C%2FSPAN%3E%3CSPAN%20class%3D%22mord%20text%22%3E%3CSPAN%20class%3D%22mord%22%3E%E5%BE%AE%E7%A7%92%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%E8%BF%99%E5%AF%B9%E8%AE%B8%E5%A4%9A%E7%B3%BB%E7%BB%9F%E6%9D%A5%E8%AF%B4%E4%BB%8D%E7%84%B6%E5%BE%88%E5%BF%AB%EF%BC%8C%E4%BD%86%E5%A6%82%E6%9E%9C%E4%B8%AD%E6%96%AD%E5%BB%B6%E6%97%B6%E8%BE%83%E9%95%BF%EF%BC%8C%E8%80%8C%20MCU%20%E5%8F%88%E6%98%AF%E5%BC%82%E6%AD%A5%E9%87%87%E6%A0%B7%E7%9A%84%EF%BC%8C%E9%82%A3%E5%8F%AF%E8%83%BD%E5%B0%B1%E6%B2%A1%E5%A4%9A%E5%A4%A7%E5%85%B3%E7%B3%BB%E4%BA%86%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%3CSTRONG%3E%E9%80%BB%E8%BE%91%E7%94%B5%E5%B9%B3%E7%A8%B3%E5%AE%9A%E6%80%A7%3C%2FSTRONG%3E%EF%BC%9A%E7%94%B5%E9%98%BB%E8%B6%8A%E9%AB%98%EF%BC%8C%E6%BC%8F%E7%94%B5%E6%B5%81%EF%BC%88SPI%20%E5%BC%95%E8%84%9A%E6%9C%80%E9%AB%98%E5%8F%AF%E8%BE%BE%2010%20%C2%B5A%EF%BC%89%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%AF%BC%E8%87%B4%E6%98%8E%E6%98%BE%E7%9A%84%E7%94%B5%E5%8E%8B%E4%B8%8B%E9%99%8D%E3%80%82IRQ%20%E7%9A%84%E7%94%B5%E5%8E%8B%E5%8F%AF%E8%83%BD%E5%8F%AA%E6%9C%89%20~3.0%20V%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%203.3%20V%EF%BC%8C%E8%BF%99%E5%9C%A8%E9%80%9A%E5%B8%B8%E6%83%85%E5%86%B5%E4%B8%8B%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E5%9C%A8%E5%98%88%E6%9D%82%E7%9A%84%E7%8E%AF%E5%A2%83%E4%B8%AD%E5%8F%AF%E8%83%BD%E4%BC%9A%E6%9C%89%E5%BD%B1%E5%93%8D%E3%80%82%3C%2FP%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%3E%E5%A6%82%E6%9E%9C%E4%B8%AD%E6%96%AD%E5%93%8D%E5%BA%94%E6%97%B6%E9%97%B4%E4%BB%A5%E6%AF%AB%E7%A7%92%E4%B8%BA%E5%8D%95%E4%BD%8D%EF%BC%8C%E8%80%8C%E6%82%A8%E5%8F%88%E8%83%BD%E5%BF%8D%E5%8F%97%E8%BE%83%E6%85%A2%E7%9A%84%E4%B8%8A%E5%8D%87%E6%97%B6%E9%97%B4%EF%BC%8C%E9%82%A3%E4%B9%88%2033%20k%CE%A9%20%E5%BE%88%E5%8F%AF%E8%83%BD%E6%B2%A1%E9%97%AE%E9%A2%98%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E7%A1%AE%E4%BF%9D%0A%3CUL%3E%0A%3CLI%3E%E6%80%BB%E7%BA%BF%E7%94%B5%E5%AE%B9%E5%B9%B6%E4%B8%8D%E5%A4%A7%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E6%BC%8F%E7%94%B5%E6%B5%81%E4%B8%8D%E4%BC%9A%E5%B0%86%E7%BA%BF%E8%B7%AF%E6%8B%89%E4%BD%8E%E4%BA%8E%20VIH%EF%BC%883.3%20V%20%E9%80%BB%E8%BE%91%E7%94%B5%E5%8E%8B%E9%80%9A%E5%B8%B8%E4%B8%BA%20%26gt%3B%202%20V%EF%BC%89%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%3C%2FP%3E%0A%3CP%3E%E7%BA%A6%E7%91%9F%E5%A4%AB%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
