S32R294 QSPI multilink program
928 次查看
longfeiwang
I can use the SRAM debugging method to read and write QSPI flash, but I can't fix the code to QSPI flash and report the error as follows
923 次查看
petervlna
Hello.
I see you have issues erasing the flash. Could you please closer specify the steps you are doing?
Peter
