S32DS IDE
S32DS IDE
1,419 次查看
Paroz
Hello everyone, I am using the RDK S32R274 radar development kit. In fact, until last week I was able to use this RDK via the SD32 IDE. For some reason I had to reinstall this S32DS IDE. I encountered some problems when I tried to install and use the default project called One RF Four Antennas. I can't find any software extensions for S32r274. So I can't build and debug this project successfully. I think I need the real version of S32DS compatible with S32R274 RDK. I would appreciate it if you could give me any information about which document I can follow or which ide I should download. I know I should be interested in S32 Design Studio for Power Architecture, which I think provides the S32R274 plug-in, but I couldn't find a solution.
Thanks in advance.
Kind regards.
1,398 次查看
petervlna
To summarize it. You have reinstalled S32DS for PowerPC and now you are missing modules for RDK demo?
I see that all requirements to run the demo are in the documentation:
https://www.nxp.com/docs/en/application-note/AN12938.pdf
Could you please specify your issue in more details?
Peter
