Reserved Application Id directory - Desfire
IMTECHENGINEERING
Dear All,
We want to reserve an application Id for our corporation ? What is the procedure ?
Do we have to send you a particular document.
Thanks a lot
Yanis ISSAD
CEO
IMTECH Engineering
danielchen
The process to request an AID with NXP is described in the App note:
https://www.nxp.com/docs/en/application-note/AN10787.pdf
AnnexA of this AppNote needs to be filled
out by the customer.
IMTECHENGINEERING
Dear Daniel,
Other question, when the Annexe A is complete, to whom should I send the document ?
Yanis
danielchen
Hi @IMTECHENGINEERING
You can create a ticket to me, send the file to me.  And put "assign to Daniel Chen" in the subject or description of the case, so I can help .
IMTECHENGINEERING
Dear Daniel,
Thanks a lot. I will check the document https://www.nxp.com/docs/en/application-note/AN10787.pdf and give you an update.
Do you have french people in your support ?
Have a nice day.
Kind regards.
Yanis
danielchen
Sorry, no
