PCF8574
karelskocik
how is standby mode activated from operating mode for this component? Under what conditions will the circuit return from standby mode back to operating mode.
Thanks for the anwers.
Karel Skočík
diazmarin09
Hello Karel,
I hope all is great with you. Thank you for using the NXP communities.
The standby mode on the PCF8574 device means that the I2C interface is not active.
I hope this information helps.
David
diazmarin09
Hello Karel,
David
