ReadELF() method on Freemaster Lite issue
UserTetraWise
I have an issue while reading symbol numbers from freemaster lite by calling method ReadELF() and elf file path.
#JSONRPC
method: 'ReadELF'
parameters: .elf file_path
Issue: ConnectionResetError: [WinError 10054] An existing connection was forcibly closed by the remote host
OS: Linux, Windows
Script:Python
AELhammoudi
I was wondering if you have found a solution or workaround for this issue. Any guidance you could provide would be greatly appreciated.
Adnan El Hammoudi
