RW612: Using external NOR Flash on the PSRAM-QSPI lines
705件の閲覧回数
rkapoor
I am working on a custom board based on the RW612 module.
The module provides two QSPI/FlexSPI interfaces:
  • Port A1 → connected to the boot flash.
  • Port B1 → normally intended for an external PSRAM.
Since I do not use PSRAM, I would like to connect an external NOR Flash (Micron MT25QL01GBBB, 1 Gbit) on Port B1 instead.
My questions:
  1. Is it generally possible to use the “PSRAM port” (FlexSPI Port B1) for an additional NOR Flash device?
  2. What changes are required in the SDK examples to make this work?
    • Do I only need to configure the pin-mux for Port B1 to route to the NOR Flash pins?
    • Is it sufficient to set devicePort = kFLEXSPI_PortB1 and deviceType = kSerialNorCfgOption_DeviceType_ReadSFDP_SDR in flexspi_mem_config_t?
    • Can I rely on FLEXSPI_NOR_GenerateConfigBlockUsingSFDP to automatically configure the Micron flash device correctly?
  3. The current NOR Flash SDK examples  doesn't work when I switch the parameters to Port B1. Is there an official way or example to use a second external NOR Flash on Port B1?
My goal is to use the NOR Flash as additional storage (erase/program/read), not as a boot device.
Any guidance or examples would be greatly appreciated!
タグ(1)
0 返答(返信)
%3CLINGO-SUB%20id%3D%22lingo-sub-2172736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERW612%3A%20PSRAM-QSPI%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E5%A4%96%E9%83%A8NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2172736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%3CSTRONG%3ERW612%3C%2FSTRONG%3E%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%97%E3%81%9F%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AF%202%20%E3%81%A4%E3%81%AE%20QSPI%2FFlexSPI%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E3%83%9D%E3%83%BC%E3%83%88A1%E2%86%92%E3%83%96%E3%83%BC%E3%83%88%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E3%83%9D%E3%83%BC%E3%83%88%20B1%20%E2%86%92%20%E9%80%9A%E5%B8%B8%E3%81%AF%E5%A4%96%E9%83%A8%20PSRAM%20%E7%94%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3EPSRAM%20%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%83%9D%E3%83%BC%E3%83%88%20B1%20%E3%81%AB%3CSTRONG%3E%E5%A4%96%E9%83%A8%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20(Micron%20MT25QL01GBBB%E3%80%811%20Gbit)%3C%2FSTRONG%3E%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%3A%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%3E%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AB%E3%80%81%E3%80%8CPSRAM%20%E3%83%9D%E3%83%BC%E3%83%88%E3%80%8D(FlexSPI%20%E3%83%9D%E3%83%BC%E3%83%88%20B1)%20%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%AE%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E6%A9%9F%E8%83%BD%E3%81%95%E3%81%9B%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81SDK%20%E3%81%AE%E4%BE%8B%E3%81%AB%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E5%A4%89%E6%9B%B4%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3ENOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%94%E3%83%B3%E3%81%AB%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%9D%E3%83%BC%E3%83%88%20B1%20%E3%81%AE%E3%83%94%E3%83%B3%E3%83%9E%E3%83%AB%E3%83%81%E3%83%97%E3%83%AC%E3%82%AF%E3%82%B5%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3Eflexspi_mem_config_t%20%E3%81%A7%20devicePort%20%3D%20kFLEXSPI_PortB1%20%E3%81%8A%E3%82%88%E3%81%B3%20deviceType%20%3D%20kSerialNorCfgOption_DeviceType_ReadSFDP_SDR%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E5%8D%81%E5%88%86%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3ECAN%20FLEXSPI_NOR_GenerateConfigBlockUsingSFDP%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20Micron%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E6%AD%A3%E3%81%97%E3%81%8F%E6%A7%8B%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%81%AE%3CSTRONG%3ENOR%20Flash%20SDK%20%E3%81%AE%E4%BE%8B%E3%81%AF%E3%80%81%3C%2FSTRONG%3E%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E3%83%9D%E3%83%BC%E3%83%88%20B1%20%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%E3%81%A8%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%9D%E3%83%BC%E3%83%88%20B1%20%E3%81%A7%3CSTRONG%3E2%20%E7%95%AA%E7%9B%AE%E3%81%AE%E5%A4%96%E9%83%A8%20NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%85%AC%E5%BC%8F%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%BE%E3%81%9F%E3%81%AF%E4%BE%8B%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E7%A7%81%E3%81%AE%E7%9B%AE%E6%A8%99%E3%81%AF%E3%80%81NOR%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E3%83%96%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E8%BF%BD%E5%8A%A0%E3%81%AE%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%20(%E6%B6%88%E5%8E%BB%2F%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%2F%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A)%20%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%89%E3%82%86%E3%82%8B%E3%82%AC%E3%82%A4%E3%83%80%E3%83%B3%E3%82%B9%E3%82%84%E4%BE%8B%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
