RW612: Using external NOR Flash on the PSRAM-QSPI lines
675 次查看
rkapoor
I am working on a custom board based on the RW612 module.
The module provides two QSPI/FlexSPI interfaces:
  • Port A1 → connected to the boot flash.
  • Port B1 → normally intended for an external PSRAM.
Since I do not use PSRAM, I would like to connect an external NOR Flash (Micron MT25QL01GBBB, 1 Gbit) on Port B1 instead.
My questions:
  1. Is it generally possible to use the “PSRAM port” (FlexSPI Port B1) for an additional NOR Flash device?
  2. What changes are required in the SDK examples to make this work?
    • Do I only need to configure the pin-mux for Port B1 to route to the NOR Flash pins?
    • Is it sufficient to set devicePort = kFLEXSPI_PortB1 and deviceType = kSerialNorCfgOption_DeviceType_ReadSFDP_SDR in flexspi_mem_config_t?
    • Can I rely on FLEXSPI_NOR_GenerateConfigBlockUsingSFDP to automatically configure the Micron flash device correctly?
  3. The current NOR Flash SDK examples  doesn't work when I switch the parameters to Port B1. Is there an official way or example to use a second external NOR Flash on Port B1?
My goal is to use the NOR Flash as additional storage (erase/program/read), not as a boot device.
Any guidance or examples would be greatly appreciated!
标记 (1)
0 回复数
%3CLINGO-SUB%20id%3D%22lingo-sub-2172736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERW612%EF%BC%9A%E5%9C%A8%20PSRAM-QSPI%20%E7%BA%BF%E8%B7%AF%E4%B8%8A%E4%BD%BF%E7%94%A8%E5%A4%96%E9%83%A8%E6%88%96%E9%9D%9E%E9%97%AA%E5%AD%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2172736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%BC%80%E5%8F%91%E5%9F%BA%E4%BA%8E%20%3CSTRONG%3ERW612%3C%2FSTRONG%3E%20%E6%A8%A1%E5%9D%97%E7%9A%84%E5%AE%9A%E5%88%B6%E6%9D%BF%E3%80%82%3CBR%20%2F%3E%E6%A8%A1%E5%9D%97%E6%8F%90%E4%BE%9B%E4%B8%A4%E4%B8%AA%20QSPI%2FFlexSPI%20%E6%8E%A5%E5%8F%A3%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E7%AB%AF%E5%8F%A3%20A1%20%E2%86%92%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E5%90%AF%E5%8A%A8%E9%97%AA%E5%AD%98%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E7%AB%AF%E5%8F%A3%20B1%20%E2%86%92%20%E9%80%9A%E5%B8%B8%E7%94%A8%E4%BA%8E%E5%A4%96%E9%83%A8%20PSRAM%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E7%94%B1%E4%BA%8E%E6%88%91%E4%B8%8D%E4%BD%BF%E7%94%A8%20PSRAM%EF%BC%8C%E6%88%91%E6%83%B3%E6%94%B9%E4%B8%BA%E5%9C%A8%E7%AB%AF%E5%8F%A3%20B1%20%E4%B8%8A%E8%BF%9E%E6%8E%A5%3CSTRONG%3E%E5%A4%96%E9%83%A8%20%E6%88%96%E9%9D%9E%20%E9%97%AA%E5%AD%98%EF%BC%88%E7%BE%8E%E5%85%89%20MT25QL01GBBB%EF%BC%8C1%20Gbit%EF%BC%89%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%3E%E9%80%9A%E5%B8%B8%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E5%B0%86%20%E2%80%9CPSRAM%20%E7%AB%AF%E5%8F%A3%E2%80%9D%EF%BC%88FlexSPI%20%E7%AB%AF%E5%8F%A3%20B1%EF%BC%89%E7%94%A8%E4%BA%8E%E9%A2%9D%E5%A4%96%E7%9A%84%E6%88%96%E9%9D%9E%E9%97%AA%E5%AD%98%E8%AE%BE%E5%A4%87%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E8%A6%81%E5%AE%9E%E7%8E%B0%E8%BF%99%E4%B8%80%E7%82%B9%EF%BC%8C%E9%9C%80%E8%A6%81%E5%AF%B9%20SDK%20%E7%A4%BA%E4%BE%8B%E5%81%9A%E5%93%AA%E4%BA%9B%E4%BF%AE%E6%94%B9%EF%BC%9F%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E6%88%91%E6%98%AF%E5%90%A6%E5%8F%AA%E9%9C%80%E8%A6%81%E4%B8%BA%E7%AB%AF%E5%8F%A3%20B1%20%E9%85%8D%E7%BD%AE%E5%BC%95%E8%84%9A%E5%A4%9A%E8%B7%AF%E5%A4%8D%E7%94%A8%E5%99%A8%E5%8D%B3%E5%8F%AF%E8%B7%AF%E7%94%B1%E5%88%B0%E6%88%96%E9%9D%9E%E9%97%AA%E5%AD%98%E5%BC%95%E8%84%9A%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%9C%A8%20flexspi_mem_config_t%20%E4%B8%AD%E8%AE%BE%E7%BD%AE%20devicePort%20%3D%20kFLEXSPI_PortB1%20%E5%92%8C%20deviceType%20%3D%20kSerialNorCfgOption_DeviceType_ReadSFDP_SDR%20%E6%98%AF%E5%90%A6%E8%B6%B3%E5%A4%9F%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%88%91%E8%83%BD%E5%90%A6%E4%BE%9D%E9%9D%A0%20flexspi_nor_generateConfigBlockusingsFDP%20%E8%87%AA%E5%8A%A8%E6%AD%A3%E7%A1%AE%E9%85%8D%E7%BD%AE%E7%BE%8E%E5%85%89%E9%97%AA%E5%AD%98%E8%AE%BE%E5%A4%87%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%BD%93%E6%88%91%E5%B0%86%E5%8F%82%E6%95%B0%E5%88%87%E6%8D%A2%E5%88%B0%E7%AB%AF%E5%8F%A3%20B1%20%E6%97%B6%EF%BC%8C%E5%BD%93%E5%89%8D%E7%9A%84%E6%88%96%E9%9D%9E%20%3CSTRONG%3EFlash%20SDK%20%E7%A4%BA%E4%BE%8B%3C%2FSTRONG%3E%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%E6%9C%89%E6%B2%A1%E6%9C%89%E5%AE%98%E6%96%B9%E7%9A%84%E6%96%B9%E6%B3%95%E6%88%96%E7%A4%BA%E4%BE%8B%E5%8F%AF%E4%BB%A5%E5%9C%A8%E7%AB%AF%E5%8F%A3%20B1%20%E4%B8%8A%E4%BD%BF%E7%94%A8%3CSTRONG%3E%E7%AC%AC%E4%BA%8C%E4%B8%AA%E5%A4%96%E9%83%A8%E6%88%96%E9%9D%9E%E9%97%AA%E5%AD%98%3C%2FSTRONG%3E%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E6%88%91%E7%9A%84%E7%9B%AE%E6%A0%87%E6%98%AF%E4%BD%BF%E7%94%A8%E6%88%96%E9%9D%9E%20Flash%20%E4%BD%9C%E4%B8%BA%E9%99%84%E5%8A%A0%E5%AD%98%E5%82%A8%EF%BC%88%E6%93%A6%E9%99%A4%2F%E7%BC%96%E7%A8%8B%2F%E8%AF%BB%E5%8F%96%EF%BC%89%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E7%94%A8%E4%BD%9C%E5%BC%95%E5%AF%BC%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E8%83%BD%E6%8F%90%E4%BE%9B%E6%8C%87%E5%AF%BC%E6%88%96%E8%8C%83%E4%BE%8B%EF%BC%8C%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%EF%BC%81%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E
