RTC-PCF85263A
RTC-PCF85263A
2,204 次查看
Hariprasath_12
Hi!
info> app: Time: 00:80:56
am Reading min value like 80 but i configured 0 only. seconds incrementing perfectly
I  attached my main.c .
can help me sort out this issue.
Hari.
2,115 次查看
Hariprasath_12
Thank you, I solved that issue.
2,181 次查看
ErikaC
Earlier you found an error in your oscillator that was not generating frequency, were you able to solve that problem?
I think you are not setting the time and date correctly in your program, you could follow the sequence of commands and data to be sent as shown in table 5 of UM10301.
Regards.
