RDDRONE-BMS772
1,820件の閲覧回数
fan007
I'd like to know if the RDDRONE-BMS772 development board can perform temperature measurement, how to measure and acquire temperature data, what hardware needs to be installed on the temperature sensor interface for temperature measurement, and whether a single interface can only measure one temperature value. Also, is this model of development board a standalone board, are there any other accessories, and are there any model requirements for assembling and soldering the accessories myself?
我想知道的是RDDRONE-BMS772这个型号的开发板能够进行温度测量吗,怎么进行温度数据的测量和采集,温度传感器接口安装什么硬件可以进行温度测量,只有一个接口是否只能测量一的温度数据;同时,这个型号的开发板是只有一个单独的板子吗,有没有其他配件,自己组装焊接配件有没有型号要求。
1,791件の閲覧回数
JozefKozon
Dear Fan007,
on the RDDRONE-BMS772 there are populated three shunt temperature resistors. RT1, RT2 and RT3.
RT1 and RT2 are located on top of the board.
The RT3 is located on the bottom of the board, below the MC33772B, to measure it's temperature.
Please check the schematic attached, how the RT1 through RT3 are routed. RT1 is routed to the GPIO0, RT2 to the GPIO2 and RT3 to GPIO3. You can use the GPIO1 pin to measure temperature. You need to connect a 10k shunt resistor on the J1 connector. The GPIO4 has already different function. Therefore GPIO4 cannot be use for temperature measurement on the RDDRONE-BMS772. The GPIO5 and GPIO6 are not connected. They cannot be used. Please use the four GPIO pins for temperature measurement.
With Best Regards,
Jozef
5 返答(返信)
1,750件の閲覧回数
fan007
I'd like to know if the RDDRONE-BMS772 development board comes with any compatible accessories if purchased from the official website, or if it's just the development board and I need to purchase, install, and solder the other accessories myself.
1,740件の閲覧回数
JozefKozon
Dear Fan007,
for this, please refer to kit contains in the RDDRONE-BMS772 product page.
With Best Regards,
Jozef
1,648件の閲覧回数
fan007
我想知道RDDRONE-BMS772这种类型的开发板中的各种单元的算法是基于什么什么语言编写的,我能不能用自己的算法来替代开发板的算法来实现我自己的算法
1,792件の閲覧回数
JozefKozon
Dear Fan007,
With Best Regards,
Jozef
1,741件の閲覧回数
fan007
我想知道关于RDDRONE-BMS772这个型号的开发板,如果在官方网站上进行购买的话,是只有这个开发板吗,有没有配套的配件,还是说我在购买这个开发板进行工作时需要自行购买相关配件进行安装焊接吗;如果只有开发板官网上有可以直接购买的配件吗
%3CLINGO-SUB%20id%3D%22lingo-sub-2361017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2361017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3ERDDRONE-BMS772%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E6%B8%A9%E5%BA%A6%E6%B8%AC%E5%AE%9A%E3%81%8C%E5%8F%AF%E8%83%BD%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%80%81%E6%B8%A9%E5%BA%A6%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E6%B8%AC%E5%AE%9A%E3%81%8A%E3%82%88%E3%81%B3%E5%8F%96%E5%BE%97%E6%96%B9%E6%B3%95%E3%80%81%E6%B8%A9%E5%BA%A6%E6%B8%AC%E5%AE%9A%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E6%B8%A9%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E5%8D%98%E4%B8%80%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%A7%E6%B8%AC%E5%AE%9A%E3%81%A7%E3%81%8D%E3%82%8B%E6%B8%A9%E5%BA%A6%E5%80%A4%E3%81%AF1%E3%81%A4%E3%81%A0%E3%81%91%E3%81%AA%E3%81%AE%E3%81%8B%E3%82%92%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%81%93%E3%81%AE%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E5%8D%98%E4%BD%93%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%E4%BB%96%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B5%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B5%E3%83%AA%E3%82%92%E8%87%AA%E5%88%86%E3%81%A7%E7%B5%84%E3%81%BF%E7%AB%8B%E3%81%A6%E3%81%9F%E3%82%8A%E3%81%AF%E3%82%93%E3%81%A0%E4%BB%98%E3%81%91%E3%81%97%E3%81%9F%E3%82%8A%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%A6%81%E4%BB%B6%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E7%A7%81%E3%81%8C%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E5%9E%8B%E3%81%AE%20RDDRONE-BMS772%20%E3%81%AE%E7%99%BA%E8%A1%8C%E3%83%91%E3%83%8D%E3%83%AB%E3%81%AF%E3%80%81%E6%B8%A9%E5%BA%A6%E6%B8%AC%E5%AE%9A%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%80%81%E6%B8%A9%E5%BA%A6%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E6%B8%AC%E5%AE%9A%E3%81%A8%E5%8F%8E%E9%9B%86%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81%E6%B8%A9%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E3%83%BC%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%81%AB%E5%8F%96%E3%82%8A%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%9F%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E6%B8%A9%E5%BA%A6%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%811%20%E3%81%A4%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%81%AE%E3%81%BF%E3%81%8C%201%20%E3%81%A4%E3%81%AE%E6%B8%A9%E5%BA%A6%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%90%8C%E6%99%82%E3%81%AB%E3%80%81%E3%81%93%E3%81%AE%E5%9E%8B%E7%95%AA%E5%8F%B7%E3%81%AE%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%83%B3%E3%82%B0%20%E3%83%91%E3%83%8D%E3%83%AB%E3%81%AF%E3%80%81%E4%BB%96%E3%81%AE%E4%BB%98%E5%B1%9E%E5%93%81%E3%82%92%E6%8C%81%E3%81%9F%E3%81%AA%E3%81%84%E5%80%8B%E5%88%A5%E3%81%AE%E3%83%91%E3%83%8D%E3%83%AB%E5%AD%90%E3%81%AE%E3%81%BF%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E8%87%AA%E5%B7%B1%E7%B5%84%E3%81%BF%E7%AB%8B%E3%81%A6%E5%9E%8B%E3%81%AE%E6%8E%A5%E7%B6%9A%E9%87%91%E5%85%B7%E3%81%AF%E5%9E%8B%E7%95%AA%E5%8F%B7%E3%82%92%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2361665%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2361665%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EFan007%E6%A7%98%E3%81%B8%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%20%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2Fsmart-battery-management-for-mobile-robotics-3-6-cells%3ARDDRONE-BMS772%23documentation%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ERDDRONE-BMS772%E8%A3%BD%E5%93%81%E3%83%9A%E3%83%BC%E3%82%B8%3C%2FA%3E%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%AD%E3%83%83%E3%83%88%E5%86%85%E5%AE%B9%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JozefKozon_0-1778140498272.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JozefKozon_0-1778140498272.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JozefKozon_0-1778140498272.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384623i511F90714C3A9C17%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JozefKozon_0-1778140498272.png%22%20alt%3D%22JozefKozon_0-1778140498272.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%95%AC%E5%85%B7%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%83%A8%E3%82%BC%E3%83%95%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2361663%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2361663%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3ERDDRONE-BMS772%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%85%AC%E5%BC%8F%E3%82%B5%E3%82%A4%E3%83%88%E3%81%A7%E8%B3%BC%E5%85%A5%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%81%93%E3%81%AE%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%97%E3%81%8B%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B5%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81%E3%81%93%E3%81%AE%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E3%80%81%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%82%84%E3%81%AF%E3%82%93%E3%81%A0%E4%BB%98%E3%81%91%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E5%88%A5%E9%80%94%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B5%E3%83%AA%E3%82%92%E8%B3%BC%E5%85%A5%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%81%BF%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E5%85%AC%E5%BC%8F%E3%82%B5%E3%82%A4%E3%83%88%E3%81%8B%E3%82%89%E7%9B%B4%E6%8E%A5%E8%B3%BC%E5%85%A5%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B5%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2361650%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2361650%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CFONT%20style%3D%22vertical-align%3A%20inherit%3B%22%20dir%3D%22auto%22%3E%3CFONT%20style%3D%22vertical-align%3A%20inherit%3B%22%20dir%3D%22auto%22%3ERDDRONE-BMS772%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E5%85%AC%E5%BC%8F%E3%82%B5%E3%82%A4%E3%83%88%E3%81%8B%E3%82%89%E8%B3%BC%E5%85%A5%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B5%E3%83%AA%E3%81%8C%E4%BB%98%E5%B1%9E%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%80%81%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%81%BF%E3%81%A7%E3%80%81%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B5%E3%83%AA%E3%81%AF%E8%87%AA%E5%88%86%E3%81%A7%E8%B3%BC%E5%85%A5%E3%80%81%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%80%81%E3%81%AF%E3%82%93%E3%81%A0%E4%BB%98%E3%81%91%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2361179%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2361179%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EFan007%E6%A7%98%E3%81%B8%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ERDDRONE-BMS772%E3%81%AB%E3%81%AF%E3%80%813%E3%81%A4%E3%81%AE%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E6%B8%A9%E5%BA%A6%E6%8A%B5%E6%8A%97%EF%BC%88RT1%E3%80%81RT2%E3%80%81RT3%EF%BC%89%E3%81%8C%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ERT1%E3%81%A8RT2%E3%81%AF%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E4%B8%8A%E9%83%A8%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JozefKozon_0-1778065897203.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JozefKozon_0-1778065897203.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JozefKozon_0-1778065897203.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384492iB0D81437985AE09C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JozefKozon_0-1778065897203.png%22%20alt%3D%22JozefKozon_0-1778065897203.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ERT3%E3%81%AF%E5%9F%BA%E6%9D%BF%E3%81%AE%E5%BA%95%E9%9D%A2%E3%80%81MC33772B%E3%81%AE%E4%B8%8B%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%80%81%E3%81%9D%E3%81%AE%E6%B8%A9%E5%BA%A6%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22JozefKozon_1-1778066055709.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JozefKozon_1-1778066055709.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22JozefKozon_1-1778066055709.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F384493iEB62BBB60E9D0435%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22JozefKozon_1-1778066055709.png%22%20alt%3D%22JozefKozon_1-1778066055709.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ERT1%E3%81%8B%E3%82%89RT3%E3%81%BE%E3%81%A7%E3%81%AE%E9%85%8D%E7%B7%9A%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E6%B7%BB%E4%BB%98%E3%81%AE%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%82%92%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82RT1%E3%81%AFGPIO0%E3%81%AB%E3%80%81RT2%E3%81%AFGPIO2%E3%81%AB%E3%80%81RT3%E3%81%AFGPIO3%E3%81%AB%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82GPIO1%E3%83%94%E3%83%B3%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E6%B8%A9%E5%BA%A6%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82J1%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%81%AB10k%CE%A9%E3%81%AE%E3%82%B7%E3%83%A3%E3%83%B3%E3%83%88%E6%8A%B5%E6%8A%97%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82GPIO4%E3%81%AF%E6%97%A2%E3%81%AB%E7%95%B0%E3%81%AA%E3%82%8B%E6%A9%9F%E8%83%BD%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81RDDRONE-BMS772%E3%81%A7%E3%81%AFGPIO4%E3%82%92%E6%B8%A9%E5%BA%A6%E6%B8%AC%E5%AE%9A%E3%81%AB%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82GPIO5%E3%81%A8GPIO6%E3%81%AF%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%B8%A9%E5%BA%A6%E6%B8%AC%E5%AE%9A%E3%81%AB%E3%81%AF%E3%80%814%E3%81%A4%E3%81%AEGPIO%E3%83%94%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%95%AC%E5%85%B7%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%83%A8%E3%82%BC%E3%83%95%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2362623%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RDDRONE-BMS772%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2362623%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3ERDDRONE-BMS772%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%90%AD%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%90%84%E7%A8%AE%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%E3%81%AE%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%8C%E3%81%A9%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E8%A8%80%E8%AA%9E%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%80%81%E3%81%BE%E3%81%9F%E3%80%81%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%82%92%E8%87%AA%E5%88%86%E3%81%AE%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%A6%E5%AE%9F%E8%A3%85%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AE%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
