Questions about TJA1028
2,951件の閲覧回数
806253858
HI:
When the chip TJA1028 is switched from normal mode to sleep mode, the power is cut off, and then the chip is powered on again, at this time, whether there is voltage output at pin 8 (VCC) of the TJA1028 chip.
Thanks & Regards
Wang
ラベル(6)
タグ(1)
2,850件の閲覧回数
guoweisun
After power on the device enter into standby mode and the regulator is ON.
